02-07-20, 08:50 PM | #11 |
Junior Member
Re: Newbie but oldie! Bought a Gladius.
Seen him previously. An excellent YouTube channel.
02-07-20, 09:20 PM | #12 |
06-07-20, 09:39 AM | #13 |
Junior Member
Ok I made some progress over the weekend:-
1/. Cleaning. Did a load of that. Result is decent enough. More to do of course. Muc Off is good stuff. 2/. Servicing. Parts ordered online but I did an oil and filter change which was very straightforward. Lubed the chain too. Bike has an R&G tail tidy fitted, but a few of the leds (all on the rhs of the lamp) aren't lighting. Brake light is fine. I'll check the connection and give it a clean and spray of contact cleaner. Hopefully that'll sort it. The other thing is the neutral light/gear indicator (for neutral) are a bit temperamental. It always works when you switch on. After that it's a bit hit and miss. Put down the side stand and it always comes on. I'm assuming the side stand switch is the culprit here? p.s. Just read that putting the side stand down whilst running and in gear the engine should kill it. That's the next test. Engine runs away in neutral which I assume is fine. Last edited by RS2K; 06-07-20 at 09:45 AM. |
06-07-20, 10:28 AM | #14 | |
https://www.youtube.com/watch?v=4_qn...ature=youtu.be
06-07-20, 01:03 PM | #15 |
I have the AL7 which is the one after the Gladius. I had intermittent problems with the gear indicator switching between 1 and 2. I started leaving it in first gear overnight and the problem went away. The switch is about £100.
You can pull the switch to look at it but there's nothing you can get at to clean (ie contacts) - it runs in oil anyway. In order to replace it the alternator cover has to come off (gasket £12) because it holds the switch cable in place.
2016 SV650AL7 2023 GSX-8S |
08-07-20, 03:52 PM | #16 |
Junior Member
A few more bits done:-
1/. Engine oil and filter. Must be the easiest access ever. Didn't have a funnel but managed to get 2750mls into the engine fine. Checking the level is a breeze also. 2/. The headlamp bulb shroud was a bit lopsided and loose. I got it square again and it's solid now. Next jobs are changing the brake fluid and coolant. Weather is horrendous out this way so it might be a few days. Any tips? |
08-07-20, 04:36 PM | #17 |
Only tip would be to be thorough about getting the air out of the cooling system.
09-07-20, 04:00 PM | #18 |
Junior Member
Only managed to change the air filter today. How do you remove the airbox to clean out the drain plug?
Also where does this belong? https://photos.app.goo.gl/RVL7ERV4qVmZXEpZ6 |
09-07-20, 04:33 PM | #19 |
Looks like battery hold down strap is missing, as well as holding the battery down there are some brackets on front of strap nearest tank to hold that plug thingy that is flopping around by the petrol tank - see attached PDF photo
2016 SV650 AL7 Courage is resistance to fear, mastery of fear, not absence of fear - Mark Twain Last edited by SV650rules; 16-08-21 at 10:21 AM. |
10-07-20, 10:30 AM | #20 |
Junior Member
Must buy one of those.
All the help here is invaluable and very much appreciated. Thanks. |
Thread Tools | |
newbie/racing a Gladius | dapsrsv4 | Racing and Paddock Chat | 14 | 07-04-15 09:49 PM |
Hi - newbie with Gladius | fazerjane | Idle Banter | 22 | 30-05-09 09:25 AM |
Newbie but oldie (sort of) Bishop Auckland | Fletch SV | Pennine Massive | 1 | 18-04-07 08:52 AM |
definitely an oldie | embee | Idle Banter | 3 | 02-10-06 09:46 PM |
