Old 28-03-05, 07:23 PM   #1
BURNER
Default Alternate mirrors for original SVS
Alternate mirrors I used are these.
Can anybody see the difference?
Old 28-03-05, 07:51 PM   #2
Nice... I need foldey-in ones or I'd copy you
Old 28-03-05, 08:04 PM   #3
BURNER
Forgot to mention their origins. They're from a H*nda VFR400 NC30.
I got them from ebay for £25- the pair but any spares shop has them for £19- each.
Old 29-03-05, 09:32 AM   #4
PBx
How much better can you see?
Old 29-03-05, 10:44 AM   #5
Dan_SV
They look good, useful to know if anyone steps off...
Dan
Old 29-03-05, 06:34 PM   #6
BURNER
Less of my shoulders/elbows than before, more of the road. The mirrors themselves are smaller but the stalks are longer.
Old 31-03-05, 04:26 PM   #7
hollim
Default Do the H*nda VFR400 NC30 mirrors just fit straight on?
Hi,
Can you tell me if the H*nda VFR400 NC30 mirrors just fit directly onto the existing mountings, or whether you needed to make any alterations / brackets.
I have a 2001 SV, I think this is the K1 model.
Cheers ... Martin.
Old 31-03-05, 04:31 PM   #8
BURNER
The mounting bolts on the NC30 mirrors are too long, so I cut 10mm off the threads with a junior hacksaw.
They are also about 4mm wider apart so I "reamed" the mirror mount of the clock bracket with a 10mm bit and a battery drill. After that assemble as you would the OE mirrors using the standard nuts and fittings.
Old 31-03-05, 05:22 PM   #9
hollim
Default Thanks for info...
... I might consider doing this. I'm having a total nightmare trying to find a pattern mirror since I snapped mine off putting it away
Did you replace yours for the same reason (i.e. damage), or did you just want a better view or a change of style?
If you changed owing to damage, did you ever come across anywhere that does pattern replacements?
Cheers ... Martin.
Old 31-03-05, 06:04 PM   #10
BURNER
Replaced them because the OE items are large heavy and useless. The only good thing about them was that they folded.
Didn't look for pattern items.
Alternate "white bear" meet 30/07/08 rictus01 SELKENT 11 21-08-08 10:18 AM
Funny alternate word meanings neio79 Idle Banter 3 18-10-07 08:34 PM
Original undertray - Original rear indicators for sale kciN For Sale - SV's and SV related items 0 02-05-07 09:07 AM
