Old 23-04-13, 06:36 PM   #1
Pricey12
Question Am I missing an exhaust clamp?
Evening guys
I noticed earlier that there is no clamp on the join between my header pipe and the centre section of my exhaust, just a rusty area where it looks like there may once have been one. I pulled away a very small piece of rusty metal that was still attached (barely) - you can see where it was attached in enclosed photo. It doesn't seem to be leaking, but should there be a clamp there? Been like that since I've had the bike and I was going to touch up the rusty area with some high temp silver paint, but now I'm thinking should I put a clamp on there?
Old 23-04-13, 06:37 PM   #2
Default Re: Am I missing an exhaust clamp?
Yes, but its probably held together by corrosion
Old 23-04-13, 06:39 PM   #3
Pricey12
Ha, you are probably right
Is it worth putting one on there or leaving well alone?
Old 23-04-13, 06:40 PM   #4
Yeh should be a clamp. And polish, don't paint
Old 23-04-13, 06:46 PM   #5
Pricey12
Looks like something I need to add to my list of things to do then. God knows why it's missing Any ideas which size I would need and whether I can put it on without separating the pipes? ( I know they screw together to tighten but not sure if they can be fitted over a joined pipe).
Old 23-04-13, 07:13 PM   #6
muzikill
muzikill's Avatar
http://www.ebay.co.uk/sch/i.html?_od...clamp&_sacat=0
Take your pick.
Old 23-04-13, 07:27 PM   #7
Pricey12
Originally Posted by muzikill View Post
Ta
Looks like I need the exhaust repair kit with gaskets. Will probably put it off for a while as long as it doesn't start leaking
Old 23-04-13, 08:17 PM   #8
muzikill
muzikill's Avatar
If it doesnt leak or just slightly just put the clamp over and tighten it up to seal. Thats what its for and for a fiver cheaper than trying to fit new gaskets.
Old 23-04-13, 08:20 PM   #9
Yes! They seem to rot away to nothing there.
Its around 44mm IIRC. I used a little bit of exhaust putty just to make sure
Old 23-04-13, 08:20 PM   #10
Pricey12
Cool. Do you know if the clamps come apart so I can get it on the pipe without dismantling anything?
Exhaust pipe clamp missing. Terah SV Talk, Tuning & Tweaking 7 02-01-11 09:44 PM
sv exhaust clamp craigr91 Stuff Wanted 1 16-06-10 11:58 AM
Exhaust Clamp Size? toby_smith SV Talk, Tuning & Tweaking 3 18-05-10 08:32 AM
Exhaust clamp - where from? Surfjayce Bikes - Talk & Issues 8 06-04-10 08:39 PM
exhaust clamp DoubleD Stuff Wanted 2 29-09-06 09:48 AM
