Old 26-10-17, 07:56 PM   #1
whysub
Default Curvy Reg/Rec
Anyone have one for sale in Essex or East London? Need urgently so can collect.
Thanks
Old 27-10-17, 06:17 AM   #2
Default Re: Curvy Reg/Rec
Essex orgers are a bit thin on the ground these days.
It'd be quicker to buy an upgrade from here
http://www.electrexworld.co.uk/acata...ifier_206.html
Before you order, check how many connections you RR has, some curvies have one, later ones have 2.
Mine had 2
Old 29-10-17, 03:53 PM   #3
whysub
Found one in Essex yesterday, which I collected yesterday.
Fitted it today and still the same issues-multimeter showing it was not charging but if the brake was applied, it was showing it was charging, but not by much.
After trying all three reg/revs I have, deduced they could not all be bad. All checks on the battery (fitted 20,000 miles ago) show it is good. So then tried running a seperate earth wire from the reg/rec to the battery negative terminal-and all is good! Seems there must be a break or earthing issue in the main loom.
The bike now revs cleanly and gets to the red line quicker, and the engine feels much smoother and feels much faster. Perhaps this has been an issue since I've had the bike as it has never felt this good.
I now of course have TWO reg/recs available for sale (one genuine Suzuki, the other a pattern one)............
Swap curvy SV650s for naked curvy SV650? rezus17 For Sale - SV's and SV related items 0 31-03-14 09:43 AM
Speedo from a curvy S fit into a curvy Naked housing? Taipan SV Talk, Tuning & Tweaking 6 18-02-10 04:59 PM
Naked Curvy Bottom yoke and Curvy speedo drive 21QUEST Stuff Wanted 6 29-01-09 09:36 AM
thought i best post some here, curvy lowers on my curvy BIKER-DENE Photos 3 06-05-06 07:26 AM
