Old 31-01-11, 08:58 PM   #1
muzikill
muzikill's Avatar
Default Official part prices thread
Whilst in the process of pricing up gaskets etc i thought i would put a post in here on some findings of how much certain parts cost from suzuki... ready?
Piston rings - £42 per piston set
Selector fork - £47
3+4th Gear cog - £90
Gearbox seals - £20
i almost spewed at the price for the rings! - the piston rings already on the heads are probably still within spec...but jeez expensive or what!
but, the guy i spoke had some really good advice on what i was doing the minute i mentioned a full gasket set it was obvious to him it was a gearbox problem, asked about cleaning the piston heads and cylinders and he told me just take off the excess and leave a coating of carbon still on them, plus more advice on what wouldn't be necessary to replace on a 14-15k engine ... gotta respect the official suzuki guys eh?
The Official Christmas Bah Humbug thread... fizzwheel Idle Banter 50 11-11-09 10:04 PM
The Official Christmas Pressie thread!!! Amanda Idle Banter 2 10-11-09 05:09 PM
Discussion about s/hand part prices. petevtwin650 SV Talk, Tuning & Tweaking 28 12-09-08 05:35 PM
The (Un) Official Sat Night BBQ Thread Gordon B 2008 Annual Rideout 122 29-06-08 08:44 PM
Official rain thread dizzyblonde Idle Banter 33 22-01-08 10:34 AM
