Old 01-04-14, 11:30 AM   #1
Tigerrrr.......
Default Why don't motorbikes have fog lights?
Any particular reason?
Be safe, be seen.
Tigerrrr....... is offline   Reply With Quote
Old 01-04-14, 11:35 AM   #2
PyroUK
PyroUK's Avatar
Front I'd say no suitable place to put them, rear again no suitable place to put them.
Fronts are meant to cast low light across the road and not cause reflection in the water particles so would need to be mounted on the forks.
Rear would need to be mounted a suitable distance from rear lights to differentiate from brake lights so you would need to have an epic rear mudguard that puts the standard pointy one to shame.
Just a thought.
2011 Triumph Daytona 675, Arrow exhaust and QS!
PyroUK is offline   Reply With Quote
Old 01-04-14, 12:19 PM   #3
Default Re: Why don't motorbikes have fog lights?
Mine does...
Old 01-04-14, 12:21 PM   #4
PyroUK
PyroUK's Avatar
Are they actual fog lights or just additional lamps SO?
Old 01-04-14, 07:22 PM   #5
DJ123
DJ123's Avatar
Not required by law. Plus how often is it foggy?
BMW F800ST
Old 01-04-14, 07:34 PM   #6
PyroUK
PyroUK's Avatar
Was insanely foggy this morning over my way!
Was like Silent Hill!
Old 01-04-14, 07:36 PM   #7
Front fog lights, has a button on the lh with fog symbol.
Old 01-04-14, 07:37 PM   #8
PyroUK
PyroUK's Avatar
Fair enough that's me told!
Old 01-04-14, 08:13 PM   #9
Hasn't got a rear fog light though
Old 01-04-14, 08:36 PM   #10
Red Herring
Red Herring's Avatar
Because the vast majority of motorcyclists (there are obviously the odd exception) look plenty cool enough without the need to drive around with extra lights on.
Fog lights are supposed to only be used in conditions of seriously reduced visibility, which although not defined is generally held to be when it is less that 100m. So basically if you can see far enough to be driving at more than 40mph you shouldn't have your fog lights on!
ps: and I know 100m is approximately the stopping distance from 70mph, but that's assuming you make the instant decision to go for the brakes. It takes a fair bit of time for a driver to actually realize that what he is looking at isn't actually moving.....which is why we end up with countless pileups every time it gets a little misty!
Firefighters on motorbikes robh539 Idle Banter 8 23-07-10 05:30 PM
motorbikes and traffic lights with sensors nik_nunez Bikes - Talk & Issues 14 04-07-10 03:46 PM
No side lights, brake lights, rear lights and dashboard lights Shona Bikes - Talk & Issues 25 13-11-09 11:07 PM
Job with motorbikes or that involves them. metalmonkey Idle Banter 47 16-05-08 04:26 PM
