Old 28-04-18, 09:15 PM   #1321
munkygunn182
munkygunn182's Avatar
Default Re: The All new Reeder Megathread
Does anyone want a VTR1000? At the end of my tether with it. If the problem isn't spark timing then it's going in the sea.
2014 Triumph Explorer
1997 Honda VTR1000 - project bike - now working!
munkygunn182 is offline   Reply With Quote
Old 28-04-18, 10:18 PM   #1322
littleoldman2
littleoldman2's Avatar
Nope, it would probably mean divorce.
You'll just have to man up and get on with it. Then after countless hours of toil and all of your savings it will be complete. Lets hope at that point you like it.
Old 30-04-18, 07:17 PM   #1323
munkygunn182
It IS complete - that's the problem. Dropped the two knackered valves out, replaced them + guides + all 8 seals. Cleaned carbon from pistons while the heads were off, put it back together, re-timed it, and nothing... turns over, but won't fire. If I stick easy start in it, it combusts in the exhaust.
Going to look at ignition timing as plausible it's 180* out as timing was set from no reference point (thought done to match timing marks on crankshaft & cams gears).
If it ain't that, it's a first class ticket to the port!
Old 01-05-18, 02:02 AM   #1324
did you grind the new valves in?
did you reset the cam chain tensioners?
did you turn it over by hand first? ALWAYS turn over a rebuilt engine by hand as if it dont turn its hitting valves.
most v2 you have to set each front and back TDC so front piston at crank TDC with piston at TDC and timing marks on cams. then rear crank at TDC and rear piston at TDC and timing marks on cams. it takes two crank revolutions to complete the 4 strokes so your rear is mid way of the front so another turn of the crank to set rear. unless the book says otherwise.
Old 01-05-18, 04:35 PM   #1325
munkygunn182
Done all of the above...but no joy. Beginning to annoy me now! 1 way trip to the sea shortly.
Old 01-05-18, 05:22 PM   #1326
have you removed the coils at any point?
Old 01-05-18, 05:57 PM   #1327
munkygunn182
I have...
Old 01-05-18, 06:04 PM   #1328
have you checked to make sure that the front is firing on the front etc.etc. check the manual to see the wiring is going to the correct coil.
have you visually checked the plugs are sparking?
what year is the VTR?
Old 01-05-18, 06:54 PM   #1329
munkygunn182
1998 I believe. I didn't actually remove the coil packs from the bike, so believe they would be the right way round...BUT it is possible that I have the timing set 180* out, so my next move is to swap the packs over and see if vroom.
Old 05-05-18, 08:44 PM   #1330
Operation Loch Hunt is a go
RIP Andrew Reeder (Reeder) alextg East Anglian Revolution 15 01-06-14 07:57 PM
Sad News RIP Reeder dizzyblonde Idle Banter 265 31-05-14 09:18 PM
fao: Reeder... speedplay Idle Banter 60 23-03-12 12:32 PM
