28-02-12, 04:57 PM | #1 |
Clutch pushrod movement?
Hi, I have just replaced my clutch release worm drive and am setting up my clutch.
How much should the pushrod move when i pull the lever as it only seems to go in a fraction, maybe 2-3mm? I have set up the slip via the service manual. |
28-02-12, 08:08 PM | #2 |
Anybody?
28-02-12, 09:30 PM | #3 |
Re: Clutch pushrod movement?
It's lever, the cable moves and the rod moves less - but with more shove.
As you say, the rod only moves a few mms, are you having a problem with the clutch?
28-02-12, 09:40 PM | #4 |
The rod only moves a few mm but the bike is not fully back together so cant test if it's working properly.
29-02-12, 12:50 PM | #5 |
Quite normal. Was looking at the amount of travel mine had last night when I was checking my sprocket size and it was about the same.
We are the Goon Squad and we're coming to town, BEEP BEEP! |
29-02-12, 12:56 PM | #6 |
Thanks Sir Trev!
EMDR (Eye Movement Desensitisation and Reprocessing) | Rai86 | Idle Banter | 3 | 15-05-10 12:23 AM |
Clutch pushrod? | jason13 | SV Talk, Tuning & Tweaking | 4 | 03-08-09 12:16 PM |
Throttle movement question when fitting r6 twistgrip | Loser | SV Talk, Tuning & Tweaking | 6 | 23-07-09 02:17 PM |
disc movement | Dave20046 | SV Talk, Tuning & Tweaking | 23 | 30-03-09 05:54 PM |
SV650 Clutch Pushrod Question | archerz | SV Talk, Tuning & Tweaking | 2 | 21-01-08 12:28 PM |
