12-06-19, 01:47 PM | #31 |
Re: Intermittent Start
My typing is rubbish, I often shorte thin just because I'm laz
Thanks thouhg. My speelings pretty bad too. |
12-06-19, 02:11 PM | #32 | |
Try this from Wemoto. It's more expensive but it's from a reputable supplier. |
12-06-19, 03:01 PM | #33 |
If battery is failing it can make starter solenoid chatter, it goes like this....
2016 SV650 AL7 Courage is resistance to fear, mastery of fear, not absence of fear - Mark Twain Last edited by SV650rules; 12-06-19 at 03:03 PM. |
12-06-19, 03:05 PM | #34 |
Before spending any money Id check all the connections on top of the obvious ones you have already done. These include the battery terminals and the frame and engine earths as well as the block connecters. Then buy a new solenoid
12-06-19, 03:14 PM | #35 | |
Intermittent Start
As above, the OP should check the battery is holding charge first. For OP: Just set the multimeter to a fairly low DC volts scale (there is normally one around 20V). With the ignition off test the voltage across the battery terminals, it should be 12.6v. If it is less than that the battery is not holding charge (and that will probably be causing the problem). Sent from my iPad using Tapatalk Last edited by Othen; 12-06-19 at 04:02 PM. |
12-06-19, 04:04 PM | #36 | |
I have no view on what the OP should spend his money on. One is a £10 part, the other is £30... I know which one I would fit Sent from my iPad using Tapatalk |
12-06-19, 05:20 PM | #37 |
As I said, I have a number of well made Chinese mechanical components on my very well used SV. I have in the past made the mistake of thinking that the same quality extends to imported/ebay electrical bits. I invariably end up spending a second time to replace the poor quality and occasionally downright dangerous electrical bits from sellers such as the one to which you linked.
21-06-19, 09:08 PM | #38 |
24-06-19, 06:10 PM | #39 |
How you doing mate?
Found that my clutch lever has worn enough so that the switch only engages when the lever is angled upwards slightly... just changes my starting procedure subtley! But changing the switch did nothing, obviously.
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am. 05 SV650s now with proper suspension, hurrah! |
24-06-19, 06:20 PM | #40 | |
Well, fancy that, how did you diagnose the problem I wonder? Well done. I got rid of the clutch switch, I soldered the two wires together so it is bypassed, I’m much happier having less things to go wrong than more. Sent from my iPad using Tapatalk |
Thread Tools | |
K9 Intermittent Speedo | Zim | SV Talk, Tuning & Tweaking | 5 | 25-12-12 01:27 AM |
Headlights Intermittent | Hardened Rider | SV Talk, Tuning & Tweaking | 1 | 15-09-10 08:01 PM |
Intermittent Speedo | kbh | SV Talk, Tuning & Tweaking | 6 | 14-03-09 07:57 AM |
Intermittent speedo-help please | monkey | SV Talk, Tuning & Tweaking | 3 | 16-05-07 12:26 AM |
Intermittent indicators | philb | SV Talk, Tuning & Tweaking | 3 | 11-06-05 08:15 PM |
