06-12-08, 06:00 PM | #1 |
Swing arm
When I loosen the rear axle nut to remove the rear wheel or adjust the chain, the arms of the swing arm open. Rather than being just the right distance apart for the wheel to fit, there is more room which has to be taken up by tightening the axle nut. Is this right or do I need bigger spacers or a different wheel?
K3 SV650 S Bill |
06-12-08, 06:43 PM | #2 |
Re: Swing arm
It's meant to flex a little, as it makes removing and installing the wheel a lot easier amongst other things.
Is there any lateral movement of the wheel when everything is fitted and tightened up? |
06-12-08, 06:47 PM | #3 |
Re: Swing arm
Yes the arms do flex
06-12-08, 08:04 PM | #4 |
Re: Swing arm
Nothing to worry about mate, there is flex built in to the SV swingarm which is why it springs out a little when you undo the rear axle.
07-12-08, 12:09 AM | #5 |
The Sick Man
Re: Swing arm
just makesure some twit has not forgotton to put a spacer in, if the distance is any more than 1cm then there is a problem i would say, there should be a spacer on either side
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
07-12-08, 08:30 AM | #6 |
Re: Swing arm
Thanks, all. Reassuring. Once it's all tight there's no extraneaous movement.
What's the name of that thingy on the swing arm.... | Kinvig | Bikes - Talk & Issues | 11 | 27-05-08 04:30 PM |
swing arm bush | colinsv25 | SV Talk, Tuning & Tweaking | 10 | 27-11-07 04:56 PM |
New arm for 110k swing | Horizontal | Stuff Wanted | 3 | 24-07-07 09:06 PM |
Curvey swing arm | BILLY | SV Talk, Tuning & Tweaking | 17 | 05-10-06 04:18 PM |
braced swing arm | raymond smith | SV Talk, Tuning & Tweaking | 6 | 07-03-06 07:34 PM |
