Old 27-05-16, 11:51 AM   #1
mess6311
Default Break Light wont work with front lever......
My Sv650 99 brake light wont work when the front break lever is pulled.
I have checked the switch, the connector that goes into the switch and the connectors at the tail of the bike with a multimeter and they all seem fine (either completing the circuit or getting power). The brake light also works fine with the rear brake pedal.
I just seems to be that somewhere in the circuit there is a drop. Is obviously not the bulbs as they are working fine with the rear pedal.
Any ideas?
Old 27-05-16, 12:08 PM   #2
Default Re: Break Light wont work with front lever......
Just replace the switch?
Old 27-05-16, 12:12 PM   #3
mess6311
I could do, but there is a complete circuit in the switch. Would this not indicate no problem?
Old 27-05-16, 12:30 PM   #4
only way to tell if its the switch is to disconnect the connector at the switch and bridge the terminals of the connector. if you get light then its the switch if not then its a break elsewhere.
Old 27-05-16, 01:12 PM   #5
embee
embee's Avatar
The usual issue is the contacts in the switch get dirty, sometimes you find it makes contact when you first close the switch but as you continue to move it the light goes off again. The contacts do a wiping action inside the switch itself and the dirt can build up in different spots.
As said, if you just connect the 2 wires together as a trial and the brake light comes on (ignition on obviously), then it's the switch. If not, it's the wiring.
If the switch is temperamental, either drown it in contact cleaner (or WD40 will do) and work it in, or just replace the switch.
Old 27-05-16, 05:29 PM   #6
ManMango
ManMango's Avatar
^^ Had this exact temperamental issue with my front lever.
Same symptoms as yourself rear peddle was fine but at first front lever wouldn't do jack to the lights until a bit of a fiddle with contacts which led me to a douse of WD40 and a bit of scrubbing on the contacts, not been a problem since (at least a 1.5 years on)
Yamaha YBR 125 Custom - 2000 miles
SV650s K5 - 18/07/2014
ManMango is offline   Reply With Quote
Old 28-05-16, 06:56 AM   #7
mess6311
Cheers fellas. I will try the WD40 approach then and if not try the switch.
Cheers for the help
Old 28-05-16, 07:21 AM   #8
garynortheast
garynortheast's Avatar
I've had this a couple of times. I just pop the witch off the mount, give it a good dousing with contact cleaner put it back and it's fine again.
Break Lever + Front Right Indicator Corny Gizmo Stuff Wanted 1 29-07-15 04:10 PM
Removed Front Wheel, Front Break Lever Further Out KnightRider Bikes - Talk & Issues 4 24-01-11 07:47 PM
Chain + Sprockets, Front Break Lever and Pads - where from? Owenski SV Talk, Tuning & Tweaking 7 07-07-09 12:29 PM
Front break not lighting break light? Baz SV Talk, Tuning & Tweaking 18 14-07-08 11:52 AM
Brake light switch on front lever plowsie SV Talk, Tuning & Tweaking 1 01-08-07 11:48 AM
