Old 13-01-19, 04:53 PM   #3711
Adam Ef
Adam Ef's Avatar
Default Re: Smile of the day - What is yours?
A friend of mine once found an Ariston Q Deck record player (about £300+ worth?) in a skip in one of the more affluent areas of Bristol. Got it home and it didn't work. Changed the fuse in the plug and it came to life!
Old 13-01-19, 05:31 PM   #3712
Originally Posted by Sir Trev View Post
I have saved myself several hundred quid by spending an hour at the bench in the garage with the DVD recorder and some screwdrivers.
After a while DVD players/recorders start to act up. Simple reason is dust and dirt in the machine usually but simple players are so cheap now (£30 or so) most people just buy a new one. Ours is a recorder as we sometimes save down programmes saved on the Sky box to DVD and as it seems most new models don't let you do that, unless you record down to their own internal drive from Freeview/Freesat, I decided to have a go at cleaning it.
Outer covering comes off with a few screws and the top of the dvd unit inside comes off with another four, exposing the spindle the dvd clamps to when it spins up. The spindle was covered in bits of gunge and the whole machine was full of dust. Blew out the dust and with cotton buds soaked in electrical contact cleaner (isopropynol or rubbing alcohol would be just as effective) I carefully wiped the crud off the spindle and with a clean bud gently wiped over the head of the laser unit. Works perfectly again now. Did the same a few years back on a previous machine so I've saved a fair whack now with this trick.
There was a news report on the BEEB the other morning about fixing stuff, rather than throw it away, seems like too many folk throw stuff away when it stops working. Manufacturers haven't made it easy (Apple!) by sealing units with glue so repair shops can't open them up and fix them.
Governments are introducing legislation to force companies to make stuff easy to fix, to reduce the amount of the waste.
I rescued my mum's old DVD/HDD recorder which I'd given her, as it didn't record onto DVD any more, but I too am going to open it up, and either replace the dvd drive or do what you did Sir Trev and give it a good clean.
My Blu Ray/HDD is also a bit finicky when it comes to reading and writing to disc, so I might open that up and get a replacement drive. Might seem old hat to record to disc, but there's still stuff I want to save to disc
Old 13-01-19, 06:07 PM   #3713
garynortheast
garynortheast's Avatar
I've been fixing stuff like this for years. It goes against the grain to chuck stuff out. The amount of stuff I've fixed recently with tubes of superglue/araldite/shoegoo is huge.
garynortheast is online now   Reply With Quote
Old 13-01-19, 06:21 PM   #3714
admin
John T
admin's Avatar
I always have a go at fixing. You've got nothing to lose and everything to gain. I had the same dust problem with a cd player, a quick clean and it was working again. Plenty of "how too's" on YouTube too.
Sent from my Nexus 7 using Tapatalk
Old 14-01-19, 09:14 AM   #3715
Littlepeahead
Littlepeahead's Avatar
Skill car with my amp. Took it apart, so teamed it, new fuse. Worked again.
Not so sure the Mission speaker cone will be as easy. Cat knocked it over and broke it, it's old but such a good speaker.
Sent from my SM-G935F using Tapatalk
Old 16-01-19, 09:39 AM   #3716
ophic
ophic's Avatar
Definitely no point trying to fix stuff after my doggies have broken it. I have some really nice equipment and no remote controls
Silver SV650SK3, Fuel exhaust
Old 17-01-19, 09:11 AM   #3717
Seeker
Seeker's Avatar
Everybody seen this (it's the second one he's done):
https://www.thepoke.co.uk/2019/01/17...y-weird-funny/
Old 18-01-19, 05:37 PM   #3718
getting a warm home discount on my fuel bill
Old 24-01-19, 08:45 PM   #3719
Littlepeahead
Received an invitation to a garden party at Buckingham Palace today.
It's a nice excuse to buy a new frock.
Old 24-01-19, 09:41 PM   #3720
garynortheast
Tax return finished and submitted.
what made me smile kiggles Idle Banter 1 07-04-11 09:00 PM
Smile :o) Speedy Claire Idle Banter 5 07-10-10 08:21 AM
To make you smile gruntygiggles Idle Banter 7 03-06-10 12:45 PM
Smile... the_lone_wolf 2009 Annual Rideout 14 31-07-09 01:01 AM
First smile kitkat Photos 12 08-02-09 08:55 PM
