Old 14-12-12, 07:46 PM   #131
Default Re: Accessory Distribution Gizmo Group Buy
Muchos gracias for that Bib, I knew about the battery terminals, but not the brake light connector, I would have been looking around for ages!
As above a great bit of kit to have installed
Old 14-12-12, 07:49 PM   #132
Tomor
Tomor's Avatar
Ahh I thought it was the one under the rear seat to disconnect the rear light when you take the rear fairing off.
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 14-12-12, 08:13 PM   #133
problem with that is the connectors are about 10 times the price and as far as i'm aware the curvy and the pointy are different.
the way i have done it (thanks to Y_C) the gizmo will work on any suzuki.
Old 14-12-12, 08:50 PM   #134
Elliott
Dropped through my letter box today so will install that on sunday.
Thanks!
Old 14-12-12, 09:14 PM   #135
joshwalker094
joshwalker094's Avatar
Where do you put the fuse? My grips have a fuse in their wiring I think
RIP Reeder
JOSH WALKERRRRRRRRRRRR
Old 14-12-12, 09:38 PM   #136
muzikill
muzikill's Avatar
Thats what i thought....
Old 14-12-12, 09:41 PM   #137
have fun Elliott..
there are 3 slots just in front of the relay and this is where the fuses go. each slot is the feed for the output tails below it.
you can put all the fuses in or just the one you need makes no odds
Old 14-12-12, 09:47 PM   #138
muzikill
muzikill's Avatar
Btw you know me. I would have a step by step installation post with pics. The garage is gonna be a bit chilly so it might be a while.
What i would ask is anyone who fits any accessories please take pics and post them eg. Hot grips & charging points etc.
Old 14-12-12, 09:58 PM   #139
ok there seems to be a little confusion about how this thing plugs in but it was explained in post 11 and 76 (with picture) so to make it clear it plugs into:
the rear brake light switch and the battery + & - terminals.
how it works:
once connected the relay is fed with a live feed via the + on the battery and the relay coil is fed a live feed from the rear brake light switch. the negative is connected to the battery which supplies the return path for the relay coil and the outlets for the accessory's.
when you turn your bike ignition on it feeds a live to the relay coil and because there is a return path to the negitive of the battery it pulls the switch over to feed power to the fused outlets which is fed from the battery positive. when you turn the bike off it cuts power to the coil which in turn cuts power to the fused outlets.
for those that now don't want the gizmo as they thought it plugged into the rear tail light cluster then i will give a full refund if already paid. if you haven't paid then just PM me and i will remove your name from the list
Lance
Old 15-12-12, 02:18 AM   #140
01. LewSpeight..........PM sent..Grace
02. joshwalker094.......PM sent..Paid..Posted
03. bellisan............PM sent..Paid..Posted
04. jandn1..............PM sent..Paid..Posted
05. maviczap............PM sent..Paid..Posted
06. savage86............PM sent..Paid..Posted
07. SV_archie99.........PM sent..Paid..Posted
08. Elliott.............PM sent..Paid..Posted
09. jchu1988............PM Sent..Paid..Posted
10. trudd (two of)......PM Sent..Paid..Posted
11. Zim.................PM Sent..Paid..Posted
12. MJC-DEV.............PM Sent..Paid..Posted
13. garynortheast.......PM Sent..Paid..Posted
14. 5hort5..............PM Sent..Grace
15. Cymraeg_Atodeg......PM Sent
16. Fluffer.............PM Sent
17. SIII................PM Sent..Paid..Posted
18. The Guru............PM Sent..Paid..Posted
19. Tomor...............PM Sent..Paid..Posted
20. Rocketeer...........PM Sent..Paid..Posted
21. Nobbylad............PM Sent
22. muzikill............PM Sent..Paid..Posted
23. CodeJACK............PM Sent..Paid..Posted
24. 85jas...............PM Sent
25. scotty217...........PM Sent..Paid..Posted
26. speareig............PM Sent
27. Dave81..............PM Sent..Paid..Posted
28. a_monkey_hint.......PM Sent..Paid..Posted
29. Dansp...............PM Sent..Paid..Posted
30. saucysaunders.......PM Sent..Paid..Posted
31. Serdna..............PM Sent
32. rs2fifty(+vacuum k6)PM Sent..Paid..Posted
33. Ian P...............PM Sent..Paid..Posted
marked as posted as they are all packaged up ready to post and will be posted today (saturday 15/12/12)
Lance
Jetpack like gizmo for flying over water.... MotorPsych Idle Banter 1 28-11-11 06:36 AM
gizmo freaks.....you got to see this. rictus01 Soho Massive 16 16-02-09 04:53 PM
Nifty little gizmo riktherider Bikes - Talk & Issues 13 14-10-08 09:41 AM
What's the gizmo Ed Bikes - Talk & Issues 3 13-07-08 10:58 PM
SOLD..... G Pack Gizmo... reggie perrin For Sale - SV's and SV related items 1 16-01-06 04:52 PM
