Old 18-05-18, 07:27 AM   #31
R1ffR4ff
R1ffR4ff's Avatar
Default Re: Curvy Cold Starting Needs Running Start
Originally Posted by machulnyy View Post
Thanks for the suggestions guys.
I put some Redex in the tank to clean it out and adjusted the pilot screw (hard to tell by how much as did it without taking them off) and tightened the idle screw. Seems to have improved the situation...The loud backfiring has stopped and it doesn’t die on idle anymore. However it’s still a little uneven on idle - the Rev needle bounces about a little. Guess it needs a bit more fine tuning.
On a side note...after doing the above, went for a test ride. Thought it wasn’t as smooth at high revs and making noises so gave it some wallop (not that much). Get to a roundabout, guess who pulls up next to me? The old bill, asking to pullover. Got done for doing 88 in a 50. So at least 3 more points to be expected. Got the other 3 about 2/3 months earlier ����*♂️one expensive test ride
Bummer
Have the carbs been balanced?
Here's my old Carb balancing page,
https://cx500.000webhostapp.com/CarbBalancing.html
Old 18-05-18, 10:20 AM   #32
machulnyy
No, carbs yet to be rebalanced (synced?). Thanks for the link R1FF, will check it out.
Also still need to check for air leaks as had no WD40 at home. Will get some today.
Old 18-05-18, 01:26 PM   #33
R1ffR4ff
R1ffR4ff's Avatar
Yeh Balanced/Synced.Same diff
Old 18-05-18, 02:14 PM   #34
Red ones
Red ones's Avatar
Don't wish to put a downer on it but I'd hold off doing too much to the bike. You have 3 points already and now a band C ticket. That's 6 points or a disqualification, and a hefty fine.
Old 18-05-18, 07:44 PM   #35
machulnyy
Cor downer indeed! What’s a Band C ticket? Can still ride with 9 points, no?
Misfire on cold start - Curvy. shane1964 SV Talk, Tuning & Tweaking 11 14-10-13 06:40 PM
Curvy difficult starting in cold weather. RobG650 SV Talk, Tuning & Tweaking 12 17-12-12 09:54 PM
Curvy cold starting trouble. Goodfella SV Talk, Tuning & Tweaking 21 09-12-12 08:58 AM
Curvy cold starting? JonGeorge SV Talk, Tuning & Tweaking 13 29-09-12 02:08 PM
Cold starting curvy boot Bikes - Talk & Issues 21 27-12-09 08:35 PM
