Old 12-01-18, 09:45 AM   #21
johnnyrod
johnnyrod's Avatar
Default Re: Gear/nautral issues
Possibly. The problem I've found is that the plastic worm gets gouged by the ball bearings.
Old 12-01-18, 11:48 AM   #22
garynortheast
garynortheast's Avatar
Worth just putting new one in. I bought one from Robinsons about 3 years ago for around £47, and the difference in the clutch operation made it worth every penny.
Old 12-01-18, 12:27 PM   #23
timwilky
timwilky's Avatar
I would also second the advice from Andy65 regarding the lever
It tends to corrode causing it to then bind to the shaft.
When removing, take care to compress the fibre bush to remove. They are not replaceable. a good scrub with emery cloth inside the bore, replace the bush and some light oil.
Not Grumpy, opinionated.
Sticky gear pedal issues Sizzle Media SV Talk, Tuning & Tweaking 6 28-06-12 08:23 AM
Gear Shift Rod bent - Gear Changing problem Thaleshwar SV Talk, Tuning & Tweaking 13 05-06-10 06:28 PM
Gear change problem-can't get past 2nd gear muzikill SV Ecosse 8 13-09-07 07:45 PM
Bike Starting Issues related to Gear Shift Sponge SV Talk, Tuning & Tweaking 3 17-04-06 01:15 AM
