01-01-20, 04:52 PM | #1 |
Junior Member
SV650 Bogging down upon quick throttle response
So I washed the bike and then got this issue, so my initial guess is that it's electrical. It's also an 09.
When I turn the bike on, all is as normal. I turn the key, the go to start it, to which it just about starts up (but i think my battery needs some juice, will put it on the tender tonight) and then idles totally fine, as usual. If I slowly add throttle, it's fine. But if I wack on some throttle with any speed. It seems to bog or will stall. Also, it appears as if the STVA moves very jerkily and delayed to the action of the throttle. I think it's the STVA anyway. It's the bar that's the upper out of the two if that makes sense. Also, when I turn it off, I get a weird ratchet/clicking like noise coming from below the airbox, maybe on the right hand side? Also, any ideas if this will affect MOT? I have it in 2 days... (Links to videos to follow soon!) Last edited by Redrose; 01-01-20 at 04:54 PM. Reason: Updated bike info |
01-01-20, 05:24 PM | #2 |
Re: SV650 Bogging down upon quick throttle response
The purpose of the secondary throttle valves is to maintain a constant airflow through the inlet manifold. If they're not working correctly a sudden opening of the throttle may (will?) cause bogging. The secondary throttle valves should move smoothly - maybe the linkage needs cleaning and/or lubricating or electrical connections to STV needs spraying with ACF50
Any c28 errors? Here's an 09 SV video showing their dance: https://www.youtube.com/watch?v=2dkXIIf7U20
2016 SV650AL7 2023 GSX-8S |
01-01-20, 06:27 PM | #3 | |
Junior Member
01-01-20, 06:33 PM | #4 |
Junior Member
And no error codes. Just _ C00
01-01-20, 06:56 PM | #5 |
You haven't got water in the front spark plug have you? Sounds like one cyclinder could be flooding flooding when opening the throttle, maybe due to a lack of a spark in the front cyclinder. It's possible for a bike to run with a cyclinder down but the ECU still to be adding fuel as if all is normal.
>>> ? <<< Past: Street Triple 765rs, DRZ400s,GSXR1000 K9, VFR800 A8, ZX6R 636 2006, CRF250L, GSXR750 K7, VFR800 A7, GSXR750 L3, Street Triple 675R, MT09 Tracer, SV650s K8, CB250rsd, YBR125... |
01-01-20, 06:58 PM | #6 | |
Junior Member
01-01-20, 07:03 PM | #7 |
Pull the front plug. You'll have to unbolt the rad a bit to lean it out of the way. It's a quick thing to do to rule it out if it's not the problem. Is there a drain hole on the front cyclinder? Sometimes those get blocked up too.
I only mention it as a possibility as you stated the last thing you did to change anything was wash the bike. The other symptons don't sound like a spark problem. They may be coincidence now you're looking for something though.
01-01-20, 07:05 PM | #8 |
+ Does the front cyclinder / exhaust header get hot? Spray water on it to see... don't touch it!
Have you had the bike running long enough to get up to temperature or managed to ride it?
01-01-20, 07:08 PM | #9 |
it may be your airbox is not sealed on to the throttle bodies (the rattling you're hearing). And it's bogging down due to the flood of air coming in it can't measure.
Check the airbox is securely fastened down. |
01-01-20, 07:08 PM | #10 |
If it is the twin spark engine I am not sure how water in one of the plug recesses would affect it. Sounds like throttle body, but how washing it would affect that I don't know unless water has got into sensors, how high pressure was the hose you used ?
Unusual Throttle Response | enzoalex | SV Talk, Tuning & Tweaking | 24 | 17-06-11 10:21 PM |
Throttle Response slooooowwwwwww | plowsie | Bikes - Talk & Issues | 59 | 02-03-08 07:06 PM |
Jerky Throttle Response | I'm_a_Newbie | SV Talk, Tuning & Tweaking | 7 | 17-10-06 09:47 AM |
throttle response | Londonoz | SV Talk, Tuning & Tweaking | 8 | 19-07-05 06:24 AM |
Throttle response | kavana77 | SV Talk, Tuning & Tweaking | 8 | 04-04-05 07:50 PM |
