19-03-12, 01:22 PM | #11 |
Re: Thank you Bibio
Straight up hero btw.
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ), drop it & fix it again! K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
24-03-12, 12:50 AM | #12 |
Re: Thank you Bibio
26-03-12, 09:51 AM | #13 |
Re: Thank you Bibio
I personally think he's a bawbag!
Happy Birthday Bibio | peterco | SV Ecosse | 30 | 03-09-11 01:46 PM |
Happy Birthday Bibio | appollo1 | Idle Banter | 9 | 02-09-10 09:19 PM |
Bibio - poorly | appollo1 | SV Ecosse | 104 | 01-11-09 08:36 PM |
Happy Birthday Bibio | peterco | SV Ecosse | 15 | 03-09-09 09:20 PM |
