31-01-08, 05:01 PM | #1 |
I've got the front end Bug!! Help!
Hey guys, well after seeing the sucess of phil24_7's front end i ended up bidding on ebay for a GSXR1000 K4 front end, annnnd i won . Now i've done a few things to the bike but this will be the biggest thing i've done. Hope i'm up to it.
I need to know what i still need, so a list from someone who knows would be helpful! Now with the forks are -Forks ofcourse -Top and bottom yokes -Front wheel spindle -Speed damper, dought the sv could use it. -What else do i need on my list, brakes etc i know? Before i tell you all how much whats a good price for these forks, in good condition, so all the pictures show?
RIP Hovis - Unlucky Boyo
31-01-08, 05:08 PM | #2 |
Re: I've got the front end Bug!! Help!!
Are you thinking of fitting a Gixer wheel, or going for the Triumph wheel conversion for the Gixer forks so you can use a normal speedo drive and retain the factory fit look.
http://www.racecomp.com.au/usdfe.htm |
31-01-08, 05:15 PM | #3 | |
31-01-08, 05:23 PM | #4 |
I think there's a cream you can get for that........./runs off giggling.
Forks look nice, this is definitely something I hope to do at some stage. Take photos regularly.....and, if it's not too cheeky, a running log of the costs and where you got the bits from please |
31-01-08, 05:25 PM | #5 | |
Step one: Aquire some forks. Yep done that.
31-01-08, 05:34 PM | #6 |
There's a bit of sussing what Triumph wire goes to what Suzuki wire, but apparently it's not hard to figure out. That's it once you have the conversion spacers. You just have to know exactly what model forks, wheel, calipers and discs you have so you get the correct spacers for the job. Some forks require 2mm taking off them to allow the speedo drive to fit properly, but any decent machine shop can mill that off.
31-01-08, 06:26 PM | #7 |
1RichSV650, did I see you at weston-super-mare the other day? Don't know if you would remember, but I was the guy in the RST leathers (the girlfriend was on the back in alpinestars leathers) with the blue pointy in the bike park next to the tourist info building.
(Totally off topic I know, sorry!) |
31-01-08, 06:29 PM | #8 | |
31-01-08, 06:36 PM | #9 |
Evening.
http://gregmli.blogspot.com/search/label/DIY This site is excellent for which brakes work with what etc. Basically you need wheel, discs, mudguard, calipers. You can probably re-use your SV front tyre depending on how much sharper you want the steering to be. I'd use the SV front then fit the steering damper if its a little hairy. Doubt there will be a problem though. Bear in mind I'm doing mine with older SRAD bits, and I'm not done yet, so could be talking balls.
31-01-08, 06:40 PM | #10 |
Woohoo! First SV'er I've seen from here Have to say that your bike is super super tidy, me and the girlfriend both said that to each other when you rode it into the bike park. I'm definitely going to have to invest in some clear tail lights!
Oh, and my 33bhp restriction ends the same week as yours ;D |
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) | leegriffiths128 | Stuff Wanted | 0 | 23-07-08 09:11 PM |
Front Discs (pair) for sv650 '99 curvy + Front wheel | mikeSV | Stuff Wanted | 1 | 28-05-08 04:21 PM |
Front Discs, For those with GSXR Front Ends on thier SV's | Ter | For Sale - SV's and SV related items | 2 | 14-03-07 12:56 PM |
SV650s 2000 model, yellow. I need front central and front right fairing. | OdySV | Stuff Wanted | 0 | 25-02-07 04:47 PM |
GSXR front end swap - front tyre profile. | Khewett | SV Talk, Tuning & Tweaking | 12 | 11-05-06 11:24 AM |
