09-03-21, 03:36 AM | #11 | |
Re: Shindengen Mosfet FH080 replaced stock R/R
09-03-21, 03:38 AM | #12 |
just tested the R/R bolts. they seem to have good connectivity to several ground points including the engine - thanks.
09-03-21, 08:09 AM | #13 |
from what you've described, you have the correct voltage going into the reg/rec but the incorrect voltage coming out. Occam's Razor suggests your reg/rec is faulty.
Was it new or used?
2016 SV650AL7 2023 GSX-8S |
09-03-21, 12:28 PM | #14 |
09-03-21, 01:49 PM | #15 |
we still havent checked if theres actually an output from the RR by changing the load have we?
10-03-21, 11:32 AM | #16 |
10-03-21, 02:06 PM | #17 |
John T
Disconnect the reg/rec from the loom (but not the stator) and check the output voltage, is it still low? If it's much higher it should mean there is something on the bikes electrical system dragging down the voltage.
10-03-21, 02:40 PM | #18 |
Im not sure the RR can control its output voltage correctly without being connected to the battery - I know on cars they say never disconnect the battery with the engine running...
So I was suggesting measuring the battery volts with engine running while changing the system load. If the RR is working the voltage wont change and if not the voltage of the battery will drop as only it is supplying the demand. The extra load could be from headlight main beam but better would be heated grips or some other 12v load connected across the battery. |
10-03-21, 03:04 PM | #19 | |
John T
11-03-21, 03:52 AM | #20 |
thanks guys, will try on the weekend
mosfet reg/rec supplier? | mancboy | SV Talk, Tuning & Tweaking | 43 | 30-04-16 08:46 PM |
ZX10 MOSFET reg-rec | yorkie_chris | For Sale - Other Bikes and General biking items | 0 | 05-03-16 04:26 PM |
MOSFET rectifier | numbnutbiker | Stuff Wanted | 1 | 02-08-15 04:48 PM |
Mosfet R/R | Flybuster | Stuff Wanted | 0 | 10-04-12 04:56 PM |
Shindengen fh012aa | Johny2Bags | Stuff Wanted | 1 | 02-09-11 06:22 PM |
