07-04-21, 09:48 AM | #11 | |
Re: Curvy jacking point.
07-04-21, 04:10 PM | #12 |
I built a H frame and put straps between the handle bars and cross piece
Must admit the top of the h frame I secured to the garage roof joists - if you have nothing to replicate that then this method is obviously a non starter. I used a car jack under the engine to lift the front end up. It was 100% stable. |
07-04-21, 05:39 PM | #13 |
Cheers everyone for your ideas and suggestions, very much appreciated
for sure, been giving it lots of thought and think I have it sorted now. I've managed to cannibalise a redundant exercise bike for the base which will operate pretty much the same way an Abba stand works only using the hollow under engine casing tube for the support pin to locate to. The icing on the cake is that with all the metal parts I have I can almost completely fabricate the stand using m8 bolts and nylocs, no need for any kind of welding. Just need to do some careful/accurate measuring for front wheel ground clearance when the contraption is fitted, once the front is jacked up I can do the measuring for height needed once supported by the new stand. |
07-04-21, 09:58 PM | #14 | |
07-04-21, 10:01 PM | #15 |
I'll second that. Centre stands should be regarded as the norm by manufacturers and not an optional extra ( not even possible on sv650a bikes of course )
07-04-21, 10:23 PM | #16 |
'Can I use this kit all the time instead of using the abba Superbike Stand on the swing arm pivot?
In theory yes, however we recommend this kit is only used for when you need to remove the Swing-Arm. Although this kit is still stable and secure, using the Superbike Stand on the Swing-Arm pivot with the correct fitting kit is a far better solution for constant use. Using this kit would also be much slower as you would have to fit and remove the kit each time you use the stand.' - Excerpt from Abba Stand website FAQ's. Not too sure how this works - why not leave kit on as SV650rules suggests ?! ( presume bobbins don't interfere with rear brake and gear lever operation ! ) |
08-04-21, 04:44 PM | #17 | |
09-04-21, 12:42 PM | #18 | |
The bobbins slip into the two 'cups' on the end of the basic ABBA stand, so the normal bike specific adapters that fit into same cups no longer needed.
2016 SV650 AL7 Courage is resistance to fear, mastery of fear, not absence of fear - Mark Twain Last edited by SV650rules; 09-04-21 at 12:48 PM. |
09-04-21, 09:39 PM | #19 | |
' In most cases we would recommend that the SARK is fitted to the frame lug itself & not the outside of the hanger (although this is possible in some cases) obviously if the hanger is removed they cannot be left this way. The SARK fittings also stick out so may hinder foot movement when riding. For routine use we would always recommend using the swing-arm adapter kit on the bike & not the swing-arm removal kit. The swing-arm removal kit is primarily for just that job - removing the swing-arm. Those are our recommendations, obviously your are free to follow them or not at your own discretion/risk.' End of quote. So up to me I reckon. One thing that did occur to me was can the bobbins be tightened up adequately on the outside of the hanger ? |
10-04-21, 01:44 PM | #20 |
All I can say is I have never had a problem - and bobbins do not get in the way of anything, also much easier to locate the stand on the bobbins.
Few SV Bits For Sale - Curvy Mirrors, Point Parts | Markos_46 | For Sale - SV's and SV related items | 22 | 15-03-16 02:42 PM |
'Jacking up' a Pointy? | Dmilsey | SV Talk, Tuning & Tweaking | 13 | 16-01-14 12:04 AM |
jacking plates | olden mgroin | SV Talk, Tuning & Tweaking | 2 | 30-03-08 01:38 PM |
Jacking up the front end. | Gnome | SV Talk, Tuning & Tweaking | 20 | 25-06-07 09:54 PM |
Cutting point for Renegade standard level on a Curvy ['01] | SV650S_DUB | SV Talk, Tuning & Tweaking | 2 | 29-03-06 06:34 PM |
