Old 14-09-06, 10:12 AM   #1
Stormspiel
Default compatible shocks
Before i get flamed i've already used the search function
Which shocks are compatible with the curvy sv ?
636 B1H
SRAD 600/750 - which years this fit ? or this one ?
GSXR 1000 ? this one ?
GSXR 600/750 ? This fit ?
Busa - Which Years
I'm after upgrading and have a few lined up but am unsure which will fit.
Old 14-09-06, 10:20 AM   #2
Blue_SV650S
I presume you are after 'stiffer' rear? if so the only ones that will do you any good are the - 636 and the ZX10R ones. The 636 is a coupla mm longer, so will raise the rear that little bit more than teh ZX10R.
The GSXR's have softer springs.
I have a B1 shock in my trackbike and shorter dogbones, you might want to consider them too.
Old 14-09-06, 10:25 AM   #3
TSM
The Sick Man
TSM's Avatar
636 B1H YES
SRAD 600/750 YES
GSXR 1000 NO
GSXR 600/750 NO
Old 14-09-06, 10:28 AM   #4
Stormspiel
Ok, lets give you a background.
I know bugger all about shocks hence the mass of questions recently.
The back end of my bike feels very unstble in corners and doesn't feel planted. I get so far down in a bend and then have to raise back up as the rear feels too unstable. It's the damping seems to be the biggest problem.
The ride height isn't a problem as i can flat foot both sides and bend my knees at the minute. Dog bonnes are easily available so i'm not worried about that.
I Weight 10.5 stone and take a pillion once or twice a week at most. I don't ride near my limits with a pillion so i'm happy to sacrifice the two setup for a better solo ride.
I've been told i may be better with the SRAD given my weight and riding style.
Any comments more than welcome
Old 14-09-06, 10:35 AM   #5
Biker Biggles
Biker Biggles's Avatar
Kwak shocks tend to be quite hard,especially for your wieght,so SRAD ones may be better.Trouble is they are all really old now so getting a good one may be tricky.Is your existing shock too soft or just knackered?Have you checked your linkages and swingarm bearings for wear?Most important---Have you uprated your foek springs,as I find that having a good front end is more important than the rear.
Old 14-09-06, 10:40 AM   #6
Stormspiel
Current shock got little or no damping left in it.
Linkages etc are all fine
Forks springs should be coming for my bday depending how much i get.
Old 14-09-06, 10:44 AM   #7
Jase22
Have to disagee, 636 shock is a couple of mm shorter than the SV standard shock eye to eye.
Old 14-09-06, 01:29 PM   #8
Blue_SV650S
Not according to this list (see below) both the ZX636 and the ZX10 shocks are (slightly) longer than stock SV.
Stormspiel - this list is great (I used it and decided on a 636 shock!), they all fit the SV, make your own choice on the spring rate and length.
<Swiped>
The spring rate list copyright Lukemillar (or he posted it in my thread)
YEAR MOTORCYCLE LENGTH SPRING
00-03 GSXR750 325mm 400#
01-03 GSXR600 325.5mm 325#
01-02 GSXR1000 329.5mm 430#
03-04 SV650 330mm 430# <<<==== stock 2nd gen...05 should be the same
99-03 GSXR1300(Busa) 330mm 700#
04 GSXR750 332.5mm 408#
04 GSXR600 332.5mm 425#
03-04 GSXR1000 332.5mm 480#
99-02 SV650 337mm 510# <<<====stock 1st gen
04 ZX10R 338mm 540#
03-04 ZX6R(636) 340mm 540# *corrected by e lo...thanks!
96-99 GSXR750 345mm 375#
97-00 GSXR600 375mm 375#
05 GSX-R 1000 332.5mm 450# <<<===added by me...spring rate from racetech.com, length from ohlins.com
<end>
Old 14-09-06, 01:35 PM   #9
Jase22
I got 636 shock at 334 not 340. Doesn't make a huge difference though 6mm.
I'd recommend that shorter dog bones are fitted anyway as my hugger fouls my undertray.
Old 14-09-06, 02:01 PM   #10
TSM
The Sick Man
TSM's Avatar
are you sure its a 635 or just a ZX6 A1P shock??
K6 compatible Front brake switch Baph Stuff Wanted 3 12-02-09 11:12 PM
Sv650 and sv1000 Lower Fairing compatible? nzalog SV Talk, Tuning & Tweaking 7 28-04-08 07:43 AM
looking for info on these SVS-compatible signal/mirrors wamanning SV Talk, Tuning & Tweaking 10 10-11-07 10:04 AM
curvy sv mirrors- whats compatible Quiff Wichard Bikes - Talk & Issues 5 15-08-07 04:45 PM
Quick! AGAIN!!! Is THIS wheel compatible? snoopy SV Talk, Tuning & Tweaking 19 21-06-05 07:19 PM
