Old 26-05-09, 08:26 PM   #1
Stingo
Stingo's Avatar
Default Video file conversion
I have a couple of films on my PC in .avi file type. IIRC that type doesn't play on a conventional DVD player. I already have a file conversion programme, but I'm a bit clueless as to what to convert the file to...WMV? .mov?
Help appreciated as usual from the font of knowledge.
Twitter: @poseidon_ashore
Old 26-05-09, 08:40 PM   #2
sauluk
sauluk's Avatar
Default Re: Video file conversion
You'll need a suite that can burn them to an iso format (standard DVD) or a DVD player that is capable of playing other video formats.
Now: 12 Multistrada 1200
Was: 09 R1200GS
Was: 08 CBR600RR
Was: Blue SK5
Was: KMX125.. stolen..
sauluk is offline   Reply With Quote
Old 26-05-09, 09:03 PM   #3
tigersaw
tigersaw's Avatar
Theres a prog out there called AVS video converter - you drag any stuff onto it and tell it to make a DVD, works a treat. Not sure if its freeware or trialware or whatever, but the copy I have seems unrestricted.
Old 26-05-09, 09:12 PM   #4
Stingo
Stingo's Avatar
Google is my friend...
Old 26-05-09, 09:20 PM   #5
tigersaw
tigersaw's Avatar
But you still need a prog to burn the DVD after its made the files. Nero or something likey.
Old 26-05-09, 10:11 PM   #6
Stingo
Stingo's Avatar
Got Nero...tis a beautiful thing...
Old 27-05-09, 07:43 AM   #7
phi-dan
phi-dan's Avatar
If you've got the full version of Nero, then you can use Nero Vision - should be in the programs menu. Pull the AVI into that, create chapters, build DVD menu, and burn.
Depending on the codec used to create the AVI, you may need to also have DivX/XVid and AC3 installed, but if you can already watch the avi you've got this covered.
phi-dan is offline   Reply With Quote
Old 27-05-09, 10:25 AM   #8
Stingo
Stingo's Avatar
Thanks for that!! I'll check it out laters.
Keyfuels POI file for Navman seedy100 Idle Banter 0 10-04-08 09:08 PM
Missing Persons File Dicky Ticker The Essex Lounge 5 22-02-08 07:05 AM
secure file server DoubleD Idle Banter 5 27-09-06 12:46 PM
BIKE FILE on men and motors kwak zzr SV Talk, Tuning & Tweaking 0 24-03-05 09:41 PM
