Old 09-06-18, 01:46 PM   #11
Default Re: Replacing Fork Springs, Advice Needed.
Originally Posted by ste12100 View Post
O, yeah I need to do that. I’ve been looking around, i’ve never welded anything, can i use jb weld?
Also after looking around, do I need to drill any additional holes or anything?
Or do i just strip them down, get new springs, full holes.
Then put them back together with the new oil?
its best to weld. dont use jbweld as it will come out. any local garage with a welder will weld the holes for a few £.
if push comes to shove then countersink the hole a little and put a countersunk screw in with a good oil resistant threadlock and leave overnight then dress the head off. dont blame me if they come out though.
you dont need to do anything else with other holes unless your using emulators.
if i had know earlier i could have done "swap out" dampers as i have a set spare but i wont be at the workshop for a few weeks.
Old 13-06-18, 10:27 AM   #12
ste12100
sorry about the late response, thanks anyways. I know someone at a local car garage, i'll see if they're able to do it. Are there any spring you recommend (mainly street riding)? I'm not sure if i need linear or progressive ones tbh.
ste12100 is offline   Reply With Quote
Old 13-06-18, 02:23 PM   #13
get linear springs.
https://www.brooksuspension.co.uk/su...ngs-03-12.html +£10 postage
Old 13-06-18, 03:27 PM   #14
Biker Biggles
Biker Biggles's Avatar
Being an idiot i just realised the rust is actually above the part where the forks are mounted to the frame, so in theory the fork shouldn't go that far in.
Just wondering, does just changing the oil make a difference? I feel i'm, easily able to push the front down, (i'm 13.5 stone 85kg) would just changing the oil to 15w make a difference.
I'm trying to limit how much i spend on it, as i've recently passed my A licence up from an A2, so i'll probably look to change it next season.(I'm putting new tyres and possible chain on it already, so i thought while the wheels are off i could look at the folks)
Id say spend the money on the suspension then keep the bike. It will see you right for many years. Bigger better newer bikes are not really that much more fun than a well sorted sv. You will save a lot of money for petrol and going places.
Old 13-06-18, 07:21 PM   #15
yokohama
Or you could buy my modded forks. (shameful marketing pitch!).
Just plug and play.
Replacing fork seals and fork set up? Ricky650 SV Talk, Tuning & Tweaking 11 26-03-12 02:20 PM
Replacing fork oil - which oil for my weight? hongman SV Talk, Tuning & Tweaking 22 27-07-10 12:13 PM
Replacing fork springs. neillyg72 SV Talk, Tuning & Tweaking 2 07-03-10 08:50 PM
Advice needed on fitting front springs pms jones SV Talk, Tuning & Tweaking 9 22-09-09 07:39 PM
Replacing fork tubes. cloister SV Talk, Tuning & Tweaking 2 23-03-08 03:14 PM
