Old 02-02-18, 02:09 PM   #11
shiftin_gear98
shiftin_gear98's Avatar
Default Re: Tyre Sealant
All great advice (as i knew you'd all give) thanks.
Ok so I'll spit at it first, then start the swearing.
Old 02-02-18, 04:17 PM   #12
shiftin_gear98
OK so I spat on it. It's not the valve seating or the core. No time to swear at it now.
Old 04-02-18, 08:20 PM   #13
Toooldtodie
Toooldtodie's Avatar
Time to swear at summat else then... plenty of candidates!
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am.
05 SV650s now with proper suspension, hurrah!
Toooldtodie is offline   Reply With Quote
Old 05-02-18, 09:10 AM   #14
shiftin_gear98
I had another slightly more involved look - didn't have time to take it all apart - plus it was sodding freezing in the garage.
However with my Abba stand and the front lift I was able to get the wheel off the ground, I found the oblong gardening bucket thing we use to be just the right size. Filled it up and with the aid of a very bright torch (no not the Gamma 3) I was able to see the tiniest trace of bubbles coming from the base of the valve. I let all the air out, wiggled the valve as best I could and re-inflated. No more bubbles. I will leave it a day or two to see if this has helped. Basically if it hasn't it looks like the tyre will have to come off next weekend. Queue the swearing then. (I may swear at other things between now and then)
Old 05-02-18, 02:32 PM   #15
garynortheast
garynortheast's Avatar
Originally Posted by shiftin_gear98 View Post
, Filled it up and with the aid of a very bright torch (no not the Gamma 3)
I have to confess to using the Gamma 3 in the garage........
Exhaust Sealant? JESSWOOD2 SV Talk, Tuning & Tweaking 13 03-06-10 08:47 PM
exhast sealant barwel1992 Bikes - Talk & Issues 6 06-10-09 04:53 PM
Thread sealant radicalry00 SV Talk, Tuning & Tweaking 8 18-09-09 06:36 AM
Sealant danf1234 SV Talk, Tuning & Tweaking 4 17-02-07 11:54 AM
what solvent and sealant? lukemillar SV Talk, Tuning & Tweaking 7 11-09-06 04:44 PM
