Old 13-02-18, 11:06 AM   #21
DomP
Default Re: Is this sprocket too worn?
Originally Posted by Seeker View Post
So, that's cleared up then
Shall we resolve oil or tyres next? Just kidding
I must admit, I looked at the sprocket made my opinion (which I'm keeping to myself) read other comments, thought "what?" and took another look and thought "well, ok, maybe", took another look and thought "nah".
Still, it keeps me occupied and stops me bothering other people (until I start thinking out aloud).
For what it's worth its staying on!
I've moved on to shall I flush the coolant and brake fluid now, both of which I think are more urgent
Sent from my SM-G903F using Tapatalk
Black 2010 SV650S Fully faired
White 2011 YZF R125 sold
DomP is offline   Reply With Quote
Old 13-02-18, 12:49 PM   #22
SV650rules
Yeah, replacing brake fluid regularly can prevent corrosion in the system and pay dividends in the longer term. Modern coolants are good for a least 5 years (10 years in a car) - how old is the Daytona ?
2016 SV650 AL7
Old 13-02-18, 12:50 PM   #23
DomP
2012
Old 13-02-18, 12:52 PM   #24
SV650rules
Here is recent thread on coolant.. enjoy
http://forums.sv650.org/showthread.php?t=229185
2016 SV650 AL7
Old 13-02-18, 04:05 PM   #25
i can only see a pic of a front sprocket and to me it looks like new so no need to change it.
there is a simple test on rear sprockets/chains. if you can insert a pencil between the chain and sprocket tooth then your chain and sprockets need changed as they are fubar.
visual inspection, if the teeth on a sprocket are 'hooked' then they need changed.
i have said it before but a scottoiler is the key to chain & sprocket life. if you have OCD then use 'dry lube' and put up with shorter chain & sprocket life.
cracking the throttle open to get your kicks also reduces the life of tyres, chain & sprockets.
Old 13-02-18, 04:08 PM   #26
DomP
I used a scottoiler on my sv but there is little to no room to fit one on a Daytona 675 without it looking ugly and let's face it it's half the reason I got a 675
Old 13-02-18, 05:21 PM   #27
DomP
Good lunchtime read that was, thanks!
Curvy rear brake disc, sprocket and sprocket carrier Bunkle Stuff Wanted 2 05-04-14 10:08 AM
And the award for the most worn chain and sprocket goes to.. LewSpeight Bikes - Talk & Issues 20 25-04-13 10:32 PM
Kreiga R25 worn once SVRIDER07 For Sale - Other Bikes and General biking items 0 04-07-12 07:45 PM
Standard front sprocket, bigger rear sprocket, how many more links in chain required? Holdup Bikes - Talk & Issues 6 27-02-12 12:40 PM
part worn 180/55/17 husky03 Stuff Wanted 0 02-02-11 09:11 PM
