Old 06-12-18, 08:11 PM   #11
mdh
Default Re: Bike won't start
Originally Posted by Toooldtodie View Post
Headlight dims as you hit the starter button.
As Bibio says, it's the clutch switch. If you clean it, etc and it still doesn't work you can bypass it temporarily while you arrange for a replacement.
Simply unplug the connector and ram a u-shaped piece of wire between the two contacts and switch will be bypassed. Not a long-term solution!
Thanks, will look at it over weekend.
Old 09-12-18, 04:46 PM   #12
Crawling Finn
My 2014 Gladys had similar symptoms which disappeared by cleaning the contacts inside right hand switch gear. Headlight should go off when you hit the starter button so it is not necessary sign of load.
Crawling Finn is offline   Reply With Quote
Old 20-12-18, 07:19 PM   #13
mdh
After cleaning the clutch switch and spraying with ACF-50 the problem occurs a lot less. Service is due in 1.5k miles so I'll have the electrics thoroughly checked.
bike won't start again formula400 Bikes - Talk & Issues 6 23-09-12 12:10 PM
Bike won't start Danger Mouse SV Talk, Tuning & Tweaking 17 05-02-10 04:50 PM
My Bike Won't Start! Yellow Bikes - Talk & Issues 4 01-09-07 08:31 PM
Bike won't start!!!! doe SV Talk, Tuning & Tweaking 20 27-04-06 12:54 PM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
