22-09-20, 07:29 AM | #11 |
Re: Tyre levers
So I ended up ordering the JMP "Professional" set from M&P with a few other bits I needed:
I've spotted this as well though, which is similar to my bead breaker but more advanced. Tempting and just £85... https://www.youtube.com/watch?v=ZP6cRltuPSQ
- K9 SV650S: Hel brake lines, carbon end can - SZR660: The project... - K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now) |
22-09-20, 09:23 AM | #12 |
Re: Tyre levers
I've got a set like this,
https://tinyurl.com/y2evc2cv The extra 3rd spoon makes it easier. I also use this(Bead Lube/Paste) https://www.ebay.co.uk/itm/PREMIUM-T...YAAOSwJeVd4UQu One of my first jobs when I left school was as a Tyre-fitter. For breaking beads I use a Rag and a Garden spade as per this video, https://www.youtube.com/watch?v=mHHzCxMvxAM For Balancing I use my Wheelie bins and place the Wheel between the two using the axle I use a Rubber Camping mallet to knock new tyre over rim if required.
"Stultus est sicut stultus facit" Last edited by R1ffR4ff; 22-09-20 at 09:43 AM. |
22-09-20, 09:59 AM | #13 |
Re: Tyre levers
I haven't used tyre levers for ever, but I remember there was always 3 in a set - why do many come as a set of 2 now ?
22-09-20, 10:05 AM | #14 |
Re: Tyre levers
Probably so you have to buy two sets. It's like ice creams (magnums etc) that come in boxes of 3. Need to buy two boxes in our house to avoid an argument over who gets the last one
22-09-20, 10:05 AM | #15 |
Re: Tyre levers
No Idea M8. I've always used three
22-09-20, 08:47 PM | #16 |
Re: Tyre levers
24-09-20, 11:37 AM | #17 |
Re: Tyre levers
So the JMP levers arrived today. If it helps anyone: I've not used them yet, but they're a good length, feel solid, nice clean forgings with rounded edges/tips. Textured finish like German hand tools (I *think* they're a German company) but no COO, so no doubt made in Asia (if it matters).
27-09-20, 02:12 PM | #18 |
Re: Tyre levers
Levers worked great for getting the old tyres off.
For installing the new tyres, I used the duct tape method to pinch the tyre beads and with a little tyre lube was able to easily push the tyres onto the rim with no levers or tools in seconds, and fairly low effort (and no swearing). I'm pretty pleased with myself - wish I'd known this trick years ago. I spent far more time and effort particularly at the rear of the bike, removing/replacing the wheel, as well as cleaning, re-greasing (I say re-greasing, but I suppose that implies there was grease to start with) and so on. The replacement Michelin tyres (Road 5) have no heavy-spot marker, which I thought was weird. I googled and they apparently don't think it's necessary. I certainly found a heavy spot - I put the tyres on the rim and then onto the balancer before inflating them onto the bead to try and get it as close to balanced as I could and limit the amount of weights I'd need. I was then able to move the tyre around the rim to try and find the "best" position. The rear tyre I managed to get away with 15g (originally it had no weights). The front tyre is going to need something North of 20g (having removed 10g of old/original clip-on type) - I ran out of weights so need to order some online to finish the job.
Set off tyre warmers will take upto a 190 rear tyre £80 | sv650k4 | For Sale - Other Bikes and General biking items | 8 | 01-10-13 11:07 AM |
Curvy Carbs, clutch levers and brake levers | 21QUEST | For Sale - SV's and SV related items | 2 | 03-03-10 11:04 AM |
Tyre levers | tigersaw | Idle Banter | 9 | 22-09-09 11:58 AM |
Road Tyre Pressures and tyre problems | G | Bikes - Talk & Issues | 14 | 05-06-08 03:29 PM |
Tyre levers - anyone here have? | Stu | Guildford Massive | 8 | 08-04-08 10:33 AM |
