Old 26-03-08, 04:42 PM   #1
fourstrokebeast
Default problem with flasher relay.
hey everyone,
graet day yesterday i finally had my sv650s k6 de-restricted and fitted my new tail tidy and integrated tail light, but there is one problem...
as i switch on the indicators ive realised they are flashing to fast does anyone know what relay i might need or if there is a simple solution to this????
cheers in advance
Old 27-03-08, 07:03 PM   #2
TOLAROS
TOLAROS's Avatar
Default Re: problem with flasher relay....
Have the same problem...SV650s 1999.Real idicators are stock,front indicators are Valter Moto.I will ask a mechanic and will let know,plese do the same if you find out
TOLAROS is offline   Reply With Quote
Old 27-03-08, 07:24 PM   #3
silent11
buy a larger flasher relay that should slow them down
http://i35.photobucket.com/albums/d185/phild11/4sig.jpg
SEXY SV650S Full Faired K6 lots of mods to come
silent11 is offline   Reply With Quote
Old 28-03-08, 12:19 PM   #4
You need a different relay to solve this, simple enough to fit.
Old 28-03-08, 02:45 PM   #5
jambo
jambo's Avatar
you can add resistors to the wiring where the after-market indicators are as if they use LEDs rather than filiment bulbs they have less resistance. The flasher relay in there as standard uses a charging / discharging circuit to do the timing, so adding resistance slows the cycle back down again.
Or you've got a bulb blown and not thought to look at the other end of the bike
Old 28-03-08, 03:05 PM   #6
silent11
iam in the same position just fitted tail tidy and the indis are flashing to quick
i cant seem to find the relay where about is it??
Old 28-03-08, 03:39 PM   #7
silent11
it ok doesnt matter now found it
but does anyone know where i can get a high voltage one??
thanks
phil
Old 28-03-08, 05:10 PM   #8
jambo
jambo's Avatar
thanks
phil
The bike's electrics are 12V so that's what the flasher unit provides. I'm not sure you'd need more than 12V....
Old 28-03-08, 05:18 PM   #9
padmane
Voltage has nothing to do with it. Its the current.
Just fit resisters across the indicators or fit a LED flasher relay.
Old 28-03-08, 08:03 PM   #10
silent11
yeah sry its cause on me rs when i fitted the indi's i changed the relay for a "bigger" one and it sorted out the problem,
but i cant seem to find a relay for the suzuki only universal ones which arnt the same connector anyway, and i dont fancy paying for a resistor at ?6 each
anybody no where i can get one from
thanks phil
Where is the flasher unit?????? terryhopkins SV Talk, Tuning & Tweaking 7 18-03-08 05:10 PM
led flasher .......need wiring help please Marksv SV Talk, Tuning & Tweaking 4 15-03-08 11:21 PM
WANTED asap flasher/multi function relay sv650k4 Stuff Wanted 6 24-01-08 09:59 PM
Flasher Relay installation - might have done something bad... R-Razor SV Talk, Tuning & Tweaking 7 07-10-07 12:28 AM
Relay problem tomjones2 Bikes - Talk & Issues 14 23-05-07 11:23 AM
