Old 24-02-08, 07:13 PM   #1
tradedog
Default Rebuild help needed
Hallo all
Finally putting my crashed and repaired K5 pointy back together after an 18 month delay. Its going fairly smoothly but would anyone who has their tank off take a couple of high res (ish) pics of what happens under the tank. I am looking for where the looms routed, where the plug leads run etc. I am also confused by the the thin rubber pipe which runs from the neck of the coolant reservoir and then T pieces into 2. What is this for and where do these pipes go?
Any help would be greatly appreciated.
Old 24-02-08, 07:49 PM   #2
mc_phers0n
Default Re: Rebuild help needed
got this one if its any good to you?? might be a bit too close up for what you need..
HTH
Old 25-02-08, 05:51 AM   #3
tradedog
Thx Mc
Actually that pic is pretty good. If u have any others please post.
Any idea what the pipe coming from the coolant reservoir neck is for?
Old 25-02-08, 08:16 AM   #4
21QUEST
21QUEST's Avatar
http://www.sv650.org/SV_service_manu...nformation.pdf
Ben
Nemo me impune lacessit.
Rebuild. John 675 SV Talk, Tuning & Tweaking 15 26-08-08 06:22 PM
Should I rebuild it or should i break it? rob13 SV Talk, Tuning & Tweaking 5 21-05-08 09:33 AM
Continuing rebuild of a SV Grinch SV Talk, Tuning & Tweaking 2 22-06-07 01:36 PM
The rebuild!! Jester666 Soho Massive 2 20-05-07 12:22 PM
Help for winter rebuild! Jester666 SV Talk, Tuning & Tweaking 11 13-12-06 08:53 PM
