Old 19-03-17, 08:59 AM   #1
DryRob
Default Replacing the horn
My horn seems to be on it's way out so I've decided to replace it with something a bit louder.
Can I stick anything that's 12V on?
I was thinking of going to a scrap yard for a car horn
DryRob is offline   Reply With Quote
Old 19-03-17, 09:14 AM   #2
SheepShagger
Default Re: Replacing the horn
Can't see why not if it fits, they all work the same way
Sent from my SM-G935F using Tapatalk
SheepShagger is offline   Reply With Quote
Old 19-03-17, 11:42 AM   #3
I used a Stebel Nautilus, split the compressor from the horn and used the relay supplied with it, as above.
Compressor in the seat unit, horn in the fairing, connected by some plastic tubing.
Much louder than stock
Old 19-03-17, 12:36 PM   #4
R1ffR4ff
R1ffR4ff's Avatar
As maviczap says.If you use a high powered one watch the current draw.
I have an older single Stebel on a CX500 which didn't need a relay as it came as a pair which would have needed a relay.
I'd take a punt on one of these:Advertised @115 Db.
£5.95
http://www.ebay.co.uk/itm/12v-Replac...cAAOSwmLlX83AI
HTH
Old 19-03-17, 02:34 PM   #5
Stilo
Stilo's Avatar
Ive got a genuine pointy horn you can have for £5 + p&p
He was a hairy handed Gent who ran amok in Kent Awhooo
Stilo is offline   Reply With Quote
Old 19-03-17, 08:28 PM   #6
Adam Ef
Adam Ef's Avatar
Are you sure it's on it's way out? The screw on the back of mine drifts undone sometimes and then then rise in temp from the radiator causes it to stop working mid rides. Took me a while to work out why it worked on startup all the time and stopped once warm. The heat was enough to make the misadjustment slightly worse to the point that it didn't function. Once I readjusted the screw it was all good again.
Old 19-03-17, 09:27 PM   #7
ophic
ophic's Avatar
I got this:
http://www.ebay.co.uk/itm/221675979432
Like Maviczap's suggestion, but cheap and comes with the required relay. It can be mounted without splitting it but it's neater if it is. Mine isn't split, mounted on a custom bracket hanging off the side of the radiator near where the original was. The relay is mounted on the original horn bracket.
They do wear out quite quickly though. I'm on my third in about 5 years. The first was a genuine Stebel. From what I can see there's barely any difference between these and the cheap copies.
Silver SV650SK3, Fuel exhaust
Old 20-03-17, 08:28 AM   #8
Blapper
Blapper's Avatar
Yeah, twice I've pulled up alongside a car and tooted my standard horn and they haven't noticed at all. I want something very loud but very compact to replace it.
Old 20-03-17, 09:45 AM   #9
DryRob
That's more or less the problem, I'll have a look tonight.
Old 20-03-17, 09:48 AM   #10
tom_e
I've moved my standard horn to in front of the radiator. I bent the thin OEM bracket into an L shape and bolted it to the rad cover screw.
It's stopped my horn being cooked by the front cyl and radiator and it now actually works while being ridden.
tom_e is offline   Reply With Quote
Replacing the SV - is there anything better? shao Bikes - Talk & Issues 100 29-12-11 04:40 PM
Circuit Diagram: Replacing 1 horn with 2 horns ooger SV Talk, Tuning & Tweaking 72 12-03-09 08:14 PM
Battery needs replacing? maclovin SV Talk, Tuning & Tweaking 5 17-02-09 05:55 PM
Replacing stuff...... lily Idle Banter 16 11-08-08 07:54 AM
replacing the indicaters on my k5? ben650 SV Talk, Tuning & Tweaking 16 28-11-05 03:20 PM
