hi all ive been a member here now for 2 weeks posted a few bit and bobs bought a few parts and all in all you sound like a good bunch of lads and dont forget the lasses and have been very helpfull with me with finding parts for the bike ,ive joined your facebook group so hopefully when i get my bike back up and running i will be able to come and join up with ur meeting (if thats ok ) and thank you all again
Hello not so neeeeew beeee
Hi again Keith.
![]() ![]() Welcome to the .Org. Let us know what's wrong with the bike & I'm sure there'll be loads of people offering advice. ![]() What bike is it you ride btw? |
Croeso!
hello
there is a few big rideouts in the surfers section (which is south wales) if you fancy it |
yeaaa someone who can speak welsh to Mike..
welcome duck .
ooops I did it again ... new bike . cb1000r |
sv 650s k2 pearl lively with 3,800 on the clock used to be a minter not a chip on it now i need a front center fairing headlight unit ( i got a pm of someone here yesterday ,sry havent replyed yet ) and a rear brake pedal
![]() 2002 sv 650 |
Baph i take thats you on facebook
![]() 2002 sv 650 |
#9 |
aka a hens tooth!
![]() I'll have a dig around see what I can see later (about to go out), but as a temporary measure, you might be able to bolt it - depends on what you've got left of the stub & if it's overly bent or not. I had to do similar when my gear lever snapped. You'll need roughly a 5-6mm HSS drill bit & a bolt roughly the same size (I think I used a 6mm bolt with a 5.5mm drill bit, not too sure). Also two nuts for the bolt (min). A little old garden hose pipe is useful too. As you're a mechanic, I'm sure you can figure out the rest. Basically, drill, hose on bolt, nut on bolt, bolt through hole, nut on other side, tighten. It should at least get you running until you can find a hen's tooth, and done properly it'll be nice & secure - my gear lever has been like that for a good 5-6k miles now. Of course, as it's a brake lever, there's nothing to stop you riding without the rear brake - but that depends on your experience on bikes as to if you're comfortable with it. EDIT: Yup, me on facebook, I did put that in the message. ![]() |
#10 |
Tho'reet and welcome!
Triumph Tiger 800 in Venom Yellow Suzuki DRZ400E in Racing Yellow |
