Old 08-12-11, 07:30 AM   #1
Epic Monkey
Default Rear axle nuts
Hi guys
Unfortunately my socket set only goes up to 17mm and I need to tighten my chain this evening. What size are the rear axle nuts and are they both the same size?
Also, do I loosen both left and right side?
Thanks
Old 08-12-11, 07:39 AM   #2
Spanner Man
Default Re: Rear axle nuts
Good morning.
22mm on a Curvy, & 24mm on a Pointy methinks.
You will need to hold the other end of the spindle with a suitable spanner or socket.
If your bike is a Curvy model. You also need to loosen the brake torque arm bolt. Don't forget to tighten it up after adjusting the chain.
Spindle torque setting is; 65nm on a Curvy, & 100nm on a Pointy.
Cheers.
Spanner Man
Old 08-12-11, 08:00 AM   #3
zadar
You don't. It is designed to rotate around bolt. If you have to loosen it than your bolt is no good.
Old 08-12-11, 08:24 AM   #4
Spanner Man
How can a bolt be no good? It either works or it doesn't!
I think you're getting confused between caliper types.
Certain rear calipers, often found on Kawasaki's & Triumph's, have a bush inside the caliper lug. The fork on the torque arm clamps against the ends of the bush. Therefore when the wheel is moved rearwards when adjusting the chain, the bush theoretically rotates inside the caliper lug. However, It often doesn't, because the bush is seized in place.
The Curvy rear caliper has no such bush. Therefore the fork on the torque arm clamps against the outsides of the caliper lug. When moving the wheel rearwards, the lug on the caliper would be under strain if the bolt wasn't loosened.
Cheers.
Spanner Man
Old 08-12-11, 08:37 AM   #5
zadar
Bolt itself is bush, it is shouldered.
But you are right, only front one is shouldered and pivoting so you do need to loosen rear.
All my do pivot because I don't over tighten rear bolt so I don't need to do that step.
Old 08-12-11, 09:13 AM   #6
Epic Monkey
Thanks for the responses guys
I have a pointy - so I need a 24mm socket? (I have a torque wrench already)
And both nuts are the same size? The right one looks smaller.
Old 08-12-11, 09:28 AM   #7
zadar
Right side is 22mm.
Old 08-12-11, 09:29 AM   #8
Epic Monkey
Excellent. 22 and 24 socket hunting at lunch then
Thanks Chaps
Old 08-12-11, 11:27 PM   #9
Epic Monkey
How crap are the adjuster plates!?!! Tightened everything up and the right plate had shifted around and gouged out my swing arm. Aaarggh!!! Annoyed
rear axle nut torque? DaveP SV Talk, Tuning & Tweaking 16 18-09-11 02:41 AM
Removing rear axle nut? daveyrach SV Talk, Tuning & Tweaking 15 27-06-11 05:15 PM
Rear axle nut size - K5? Spiderman SV Talk, Tuning & Tweaking 13 18-05-11 11:57 AM
Rear Axle Nut TheOnlyNemesis SV Talk, Tuning & Tweaking 9 19-01-10 08:26 PM
Rear wheel axle nut sweepdoggydog Stuff Wanted 0 25-04-09 07:47 PM
