Old 13-09-10, 11:34 AM   #1
SAMMY650
Default Buying steering head bearings
Anyone used bearings brought from these guys?
http://shop.marksman-ind.com/steerin...003-1296-p.asp
Are they any good?
Thanks
Old 13-09-10, 02:28 PM   #2
Spanner Man
Default Re: Buying steering head bearings
Good afternoon.
I've not heard of them, but as they don't state which make of bearing they are, I would be suspicious....There are a lot of 'plastic' bearings around.
If you wish to go for taper rollers. Get Koyo bearings. These are excellent. You will need a 32006JRRS bearing for the bottom. This has a built in seal, & a 32006JR for the top.
Cheers.
Spanner Man
Old 13-09-10, 02:34 PM   #3
MrMessy
Are those part No's relevant for the curvy models?
MrMessy is offline   Reply With Quote
Old 13-09-10, 02:39 PM   #4
No, curvy top is smaller, 32004 maybe but check that yourself as I can't remember.
Bottom is same 32006 both.
Marksman will sell you those koyo if you ask.
Old 13-09-10, 03:37 PM   #5
SAMMY650
Many thanks guys
Old 13-09-10, 06:22 PM   #6
SAMMY650
Originally Posted by Spanner Man View Post
Good afternoon.
Cheers.
Silly question....but do the bearings i buy need to have the letters after 32006 or can they just state the 32006???
Old 13-09-10, 06:27 PM   #7
I think the JR is steel cage code and RS is rubber seal.
Not 100% about JR part though, if you just ask for 32006 you will get non sealed ones but they'll be right size.
Old 14-09-10, 05:48 AM   #8
Spanner Man
The Curvy model uses a 32005 bearing at the top.
Indeed the RS denotes that the bearing has a rubber seal.
As with most consumables, bearings vary widely in quality. I started using Koyo bearings long before YC was even in Nappies.
I had noticed that Yamaha steering bearings lasted roughly twice as long a Suzuki's. Even when correctly greased. Yamaha used Koyo bearings, & Suzuki used NTN.
Don't skimp & buy cheapo or unknown make bearings. You'll be doing the job again sooner than you think.
Cheers.
Spanner Man
Old 14-09-10, 07:18 AM   #9
MrMessy
Thanks for the info.
Fitting steering head bearings? SVGeorge SV Talk, Tuning & Tweaking 10 06-09-10 03:18 PM
steering head bearings philbond07 SV Talk, Tuning & Tweaking 26 05-04-10 09:29 PM
steering head bearings... curvy trouty SV Talk, Tuning & Tweaking 8 21-04-09 02:11 PM
Steering head bearings - lifespan? Fizzy Fish SV Talk, Tuning & Tweaking 6 30-06-08 06:37 PM
Steering Head Bearings rjh SV Talk, Tuning & Tweaking 3 13-10-04 02:12 PM
