26-07-20, 05:04 PM | #1 |
Tyre woes
Typical ... lovely sunny day, get geared up for a blast and .... flat rear tyre! Found what looks like a tin rack right in between the treads. 😡 .it's only done 800 miles. Anyway .. been looking at a new pirelli angel (what's on there atm) but was also thinking about using one of the new types of 'permanent' slime type of sealants, anyone used anything like these with good results ? Would there be a problem with a decent repair having the puncture right in between the treads?
Any advice on which way to go? Cheers. |
26-07-20, 05:28 PM | #2 |
Re: Tyre woes
Personally, having used both the slime and sticky string, I've found the latter to be the best permanent option. The alternative is to get the tyre off and have a proper repair done. Worth it if the tyre only has 800 miles on it.
The Pirelli Angel ST and the Diablo Strada before it are my favourite tyres for the SV. good in the wet or dry, great handling characteristics and a sensible price. |
26-07-20, 05:38 PM | #3 |
Re: Tyre woes
Bad luck! Repair? This would rather depend on your personality ie how cautious you are. The tyre industry prefers you to buy a new tyre (duh!) rather than get it repaired. Their argument being that your safety is resting on a tiny contact patch at the best of times.
Having said that, I have ridden several thousand miles on repaired tyres - a couple I repaired myself with sticky string and one that a tyre fitter repaired using a mushroom plug which is probably the best option. I'm generally a slow rider though. If you're a spirited (!) rider then I'd get a new tyre, if you're cautious or if it's just for low speed commuting then I'd go for a (professional) repair, I wouldn't use the slime.
2016 SV650AL7 2023 GSX-8S |
26-07-20, 05:45 PM | #4 |
Re: Tyre woes
Thanks for weighing in peeps, I pains me to change the tyre tbh with such low mileage on it, would it also be ok to repair with the puncture right in between the treads? Only asking as 99% of the videos I've seen only do a demo of the tyre being repaired on the tread areas and not in the channels??
26-07-20, 06:00 PM | #5 |
Re: Tyre woes
As long as puncture is not too near edge of tyre tread area or in sidewall you should be fine
https://www.motorcyclenews.com/new-r...ture-repairs-/
26-07-20, 08:23 PM | #6 |
Re: Tyre woes
Coming late to this but I had a roofing nail in my rear tyre less than 1,000 miles after it was fitted, in the tread groove too.
Had a proper vulcanised plug done, that was 10,000 miles ago. |
26-07-20, 08:33 PM | #7 |
Re: Tyre woes
I've had a flat in between the treads. I put one of those BMW donuts in for a temporary fix to get me to work. About 6000 miles of hooning later, I changed it.
Currently driving a Corsa.... |
26-07-20, 11:47 PM | #8 |
Re: Tyre woes
11k miles from a rear tyre??
27-07-20, 06:06 AM | #9 |
Re: Tyre woes
Get a proper repair done.
I've bought the bits to do them myself. Cost a bit more for all the tools and potions than getting someone else to do it for me. But then I had a second puncture and was quids in.
>>> ? <<< Past: Street Triple 765rs, DRZ400s,GSXR1000 K9, VFR800 A8, ZX6R 636 2006, CRF250L, GSXR750 K7, VFR800 A7, GSXR750 L3, Street Triple 675R, MT09 Tracer, SV650s K8, CB250rsd, YBR125... |
27-07-20, 08:06 AM | #10 |
Re: Tyre woes
Crash.NET - Hard tyre woes restrict Valentino Rossi | NewsBot | News | 0 | 11-07-14 04:00 PM |
Crash.NET - Jorge Lorenzo silent as tyre woes continue | NewsBot | News | 0 | 27-02-14 03:20 PM |
Crash.NET - Front tyre woes leave Bradl struggling | NewsBot | News | 0 | 13-09-13 07:40 PM |
Crash.NET - Tyre life woes for Rossi at Jerez | NewsBot | News | 0 | 23-03-13 08:40 PM |
HELP....more tyre woes!!!! | Wezza87 | Tyres | 8 | 07-04-08 07:24 PM |
