Old 30-05-20, 09:01 AM   #1
Steve
Steve's Avatar
Default Exhausted.....
Hi all, has anybody managed to fit the pointy exhaust to the much better looking curvy? if so how much needs to be altered, and id rather not touch the front downpipe.
Cheers.
Dreams & Screams go hand in hand
Steve is offline   Reply With Quote
Old 30-05-20, 07:24 PM   #2
zsv650s
Default Re: Exhausted.....
Cheers.
Hahaha good troll
zsv650s is offline   Reply With Quote
Old 31-05-20, 04:52 AM   #3
Steve
Steve's Avatar
it still don't answer the question about the exhaust..........
Old 03-06-20, 01:29 PM   #4
Steve
Steve's Avatar
come on somebody must have had a go at fitting a pointy exhaust to a curvy, since Suzuki no longer sell them.
ideally leaving the front cylinder alone as the nuts and studs don't look good.
This is not a "TROLL", I'm asking a question zsv650s.
cheers
Old 03-06-20, 02:07 PM   #5
Sean_Morgan
Delkevic sells a full system for the curvy if you get desperate
Sent from my SM-G960F using Tapatalk
Sean_Morgan is offline   Reply With Quote
Old 03-06-20, 02:30 PM   #6
Dave20046
Dave20046's Avatar
cheers
Yeah , I got it was just a bit of banter..I just didn't know the answer. I guess zsv650s just couldn't believe someone actually though the curvys looked better.
It depends on the link pipe diameter at the oem downpipe outlet. I suppose you could find a shop that sells both and check the diameter.
I've just tried for you and found the below (or just part with £30-40 for a link pipe and you can buy any can).
https://www.lextekproducts.com/LNKPP080.php
https://www.lextekproducts.com/LNKPP059SP
The former doesn't state the header diameter unfortunately but the one for the pointy states 54mm. You could either measure your own or do some more googling.
Old 03-06-20, 03:06 PM   #7
Steve
Steve's Avatar
I've got cracks just after the join to the front pipe. (NOT ME, THE BIKE).
I asked a welder and he said 20 year old stainless has been heat treated by the time and its durty inside the cracked so a good clean weld wont happen.
Old 03-06-20, 03:17 PM   #8
Dave20046
Dave20046's Avatar
Sounds like you'll need a new link pipe. Why did you want a pointy one had you seen it cheap or something?
He could poss cut and patch it or sleeve it but it's a bodge and not good for performance.
Just found the answer courtesy of Mav
https://forums.sv650.org/showthread.php?t=167081
So no, a pointy link pipe won't fit Curvy downpipe outlet (52mm). Either buy a new curvy link pipe and you can fit any old 51mm can or find a curvy second hand pair of the both can and link
Old 03-06-20, 03:46 PM   #9
Steve
Steve's Avatar
Can I attach a photo? If so how.
Old 03-06-20, 03:52 PM   #10
Steve
Steve's Avatar
Thanks all, orders a second hand exhaust with the front pipe separated.
Exhausted... mega Euro-trip over! mburnstead Bikes - Talk & Issues 6 24-05-06 02:33 PM
Exhausted Hogzi SV Talk, Tuning & Tweaking 3 14-02-06 12:43 PM
Exhausted Hogzi Stuff Wanted 1 14-02-06 10:14 AM
exhausted manxsv SV Talk, Tuning & Tweaking 11 07-09-05 07:29 PM
