Old 11-09-08, 06:23 PM   #1
Airwolf
Airwolf's Avatar
Exclamation my project gpz
i have a gpz i am doing up.
i have managed to get the engine start, a bit on the ruff side at the mo., i yet to get new plugs and leads.
the question is why can't i get over 4000 revs, i think it might be flooding a little, but i would think it would still do over 4000.
i know i should do the other bit that might resolve it, but a lot of heads it better than one. i maybe forgetting something.
SV650SY, tinted double bubble, tail tidy, belly pan, hugger, delkevic can (sounds sweet) forgot to add... in the best colour CANDY GRAND BLUE
GPX400R with gpz600 block. getting some work done by myself to get it back on the road.
Airwolf is offline   Reply With Quote
Old 11-09-08, 08:32 PM   #2
600+
Default Re: my project gpz
if it started then its progress I would suggest you change plugs first, clean the airfilter and carbs and then start it again!! if it's anything to go by my zxr400 then it will need some italian tunning to get it revving across the whole range
Old 11-09-08, 08:33 PM   #3
sv650k4
give it a service new plugs should help plugs cause more than you would think so could be them!
Old 11-09-08, 09:03 PM   #4
Airwolf
Airwolf's Avatar
thanks for your answers
the plugs will be got soon as i get a chance
Old 11-09-08, 09:05 PM   #5
Dangerous Dave
Sorry, off topic but does this have any reference to your avatar?
Old 11-09-08, 09:07 PM   #6
common problem is the coils .. i have a gpx 600 sitting in a garden.. got new coils coz it kept cutting out going round roundabouts and such like .. also sometimes wouldent go beyond 6000 rpm...
Old 11-09-08, 09:15 PM   #7
Biker Biggles
Biker Biggles's Avatar
One regular issue with old Kwaks is rust in the tank getting into the carbs causing blockages and rough running(or no running)
First port of call is the float chamber valves which can get jammed open causing flooding,then the jets get crud in them and so on.Carbs then need a strip and clean,but you need to stop the crud at source.I dont know if a fuel filter is feasable on that bike.
Old 12-09-08, 04:22 PM   #8
Airwolf
Airwolf's Avatar
yes it does.
airwolf was great when i was younger, along with the gpx / gpz
oh to be young again (but with todays cash in my pocket)
Old 12-09-08, 04:24 PM   #9
Airwolf
Airwolf's Avatar
thanks, but already has one
project xj kwak zzr Photos 109 05-08-08 12:49 PM
H*nd* project DavieSV Photos 0 07-02-08 11:11 PM
Project TLS PAPPACLART Photos 65 15-08-07 09:14 PM
What 'project' for £100 glade Bikes - Talk & Issues 20 24-10-06 07:19 PM
Project Cat D 21QUEST Photos 8 16-09-06 04:26 PM
