Old 16-05-23, 01:52 PM   #1
Kenzie
Kenzie's Avatar
Default Virtualbox on Windows 11
Hi all, does anyone have any experience using Virtualbox to run older programs? I have a Dazzle Capture device that I want to use with a Sony Handycam but the software won't run on Win 11.
Old 16-05-23, 08:15 PM   #2
admin
John T
admin's Avatar
Default Re: Virtualbox on Windows 11
I've used virtualbox for years. I'm running win98, XP and win 7(32bit) as virtuals.
I started all this because Canon failed to produce 64bit drivers for my scanner when I changed to a new PC running Win7(64bit). So I run the scanner on a virtual host using either XP or Win7(32bit). USB and other hardware is passed through the physical host to the virtual fine.
Old 16-05-23, 08:17 PM   #3
Kenzie
Kenzie's Avatar
I got the program installed, but sadly Microsoft removed the downloads for the ISOs needed to install Windows in the VM. I'll have to find another way around it
Sent from my Nokia XR20 using Tapatalk
Old 16-05-23, 08:19 PM   #4
admin
John T
admin's Avatar
I managed to get the win 7 iso from Microsoft last year. The other iso's I got searching torrents. What OS do you want?
Old 16-05-23, 08:22 PM   #5
Kenzie
Kenzie's Avatar
Either Win 7 or XP. I have discs and keys for both, just can't install them via a DVD drive.
Old 16-05-23, 08:34 PM   #6
admin
John T
admin's Avatar
I'll have a look to see if I still have the iso, if not you can have a copy of my virtual host.
Old 16-05-23, 08:54 PM   #7
admin
John T
admin's Avatar
I've sent you a virtual host. See DM. If you've got VB installed just double click on the vbox file
Old 16-05-23, 09:12 PM   #8
admin
John T
admin's Avatar
I messed up. Re uploading, might take a few mins , big file.
Old 16-05-23, 11:11 PM   #9
Kenzie
Kenzie's Avatar
On night shift tonight, so will have a look tomorrow afternoon. Thanks
Windows 8 for £25? Mark_h Idle Banter 32 24-12-12 01:15 PM
Windows 7 the_lone_wolf Idle Banter 45 25-10-09 11:31 AM
windows 7 blueto Idle Banter 13 20-09-09 06:42 PM
Windows 7 gettin2dizzy Idle Banter 15 09-04-08 12:27 PM
New Windows Law Idle Banter 61 01-02-07 11:53 PM
