Old 21-03-19, 08:30 AM   #21
glang
Default Re: Piston slap or valves?
can confirm the gasket is reusable but needs care not to damage it when lifting off the cover. I used a feeler gauge to separate it away where it was a bit stuck......
Old 21-03-19, 10:05 AM   #22
Othen
Now that is really useful information. Well done.
Old 21-03-19, 12:21 PM   #23
R1ffR4ff
R1ffR4ff's Avatar
Originally Posted by isutty5 View Post
I hear you, but when the engine is warm, the noise is gone completely, and I mean completely. It can't be cam chain! I've had a cam chain worn beyond limit and the noise was always their regardless of engine temp.
I've not gotten round to checking clutch yet but I will get to it this week! Along with a stethoscope!
As far as cracking the cover off for checking clearances, do I need a replacement gasket or is it a re-useable rubber gasket?
Also I should be able to depress the cam chain and check whether it's loose while the cover is off right?
Cheers.
Is there any chance you can get a second set of ears to listen to it.I'm fortunate that my Motorcycle MOT guy is also an ex Motorcycle racer so he knows his stuff.
Could save you a lot of time trying to find the fault.
Old 28-04-19, 07:27 PM   #24
isutty5
I was planning to crack her open shortly. Only... She's been stolen. F***ing absolute wa****s. We'll never know the truth. Sorry guys.
Old 28-04-19, 07:28 PM   #25
Othen
Eeeeeeeeek!
Sent from my iPad using Tapatalk
Old 02-08-19, 06:13 PM   #26
gt900uk
Junior Member
I had the same noise as the OP had in their video so thought I would just post on here. Mine didn't stop making the noise when the motor warmed up and I thought it was probably the CCT. Took the heads off and this is how lose the front cam chain is.
20190802_173907 by Graeme Taylor, on Flickr
20190802_173946 by Graeme Taylor, on Flickr
Just need to work out what the cause is now. Also is it normal for the timing marks to be ever so slightly off? The engine runs fine apart from the rattle but the timing marks seem just slightly off from what the Haynes manual depicts
The rear timing marks seem to do similar.
20190802_173829 by Graeme Taylor, on Flickr
20190802_174009 by Graeme Taylor, on Flickr
20190802_174037 by Graeme Taylor, on Flickr
gt900uk is offline   Reply With Quote
Old 03-08-19, 06:56 AM   #27
Seeker
Seeker's Avatar
If the cam chain is stretched would that affect the timing? They tell you to count 16 rollers between "2" on the inlet cam (vertical) and 3 mark on the exhaust, but 16 rollers distance would vary depending on chain wear (?)
https://www.manualslib.com/manual/80...age=162#manual
I've not done it so I don't know how accurate this is.
Old 03-08-19, 07:38 AM   #28
gt900uk
Junior Member
Yeah I need to check the length I guess. There are 16 pins between the marks but the IF and no 2 arrows the manual say should be level with the cylinder head seem to be pointed up slightly.
Old 03-08-19, 11:20 AM   #29
gt900uk
Junior Member
Ok so the CCT seems to be ok though it is fully extended and not tensioning the chain enough. I figure at this point it's either the chain worn or the tensioner blade that is worn. I can't find any length to measure the cam chain wear does anyone know what that would be?
Old 03-08-19, 12:35 PM   #30
Seeker
Seeker's Avatar
I looked in the SV650AL7 service manual and the only cam chain spec is the 16 rollers, there's nothing about length. It would seem your issue is tensioner related if it's max'd out. How many miles has the bike done?
In this video, at the 4min38 secs point, the guy pushes down on his curvy's camchain and it looks much tighter than yours:
https://www.youtube.com/watch?v=C1W6Vn8F9iI
Slap my Ham... gruntygiggles Idle Banter 37 15-11-10 10:23 PM
Chain slap? swinging_simian SV Talk, Tuning & Tweaking 9 31-08-09 09:43 AM
Piston Slap at 2000 miles? royboy4652 SV Talk, Tuning & Tweaking 8 16-07-08 07:55 AM
Slap a co-worker day Stu Idle Banter 2 05-10-07 11:11 AM
Well slap my tank! DanAbnormal Idle Banter 2 14-04-07 08:39 PM
