Old 31-01-16, 10:29 PM   #661
sputnik
sputnik's Avatar
Default Re: What have you tinkered with today?
Thought the bike felt a bit sticky when pushing/at standstill. No sign of hot discs but decided to go for a full caliper strip and clean. What a ball ache of a job. Always takes longer than expected and always involves some idiocy from me. That said, once it was all back together I was alarmed by how bad it must have been before (can't understand how the rotors weren't cooking). Just wish my new pads had arrived in time to fit at the same time as I'm waaay past the wear limits.
Oh, oil and filter change done too. Just realised I've left all my oily trays, funnels etc sitting in the garage. Meh, manyana...
It's like, how much more black could this be? And the answer is none. None more black.
sputnik is offline   Reply With Quote
Old 31-01-16, 10:36 PM   #662
admin
John T
admin's Avatar
Aye, i nearly got that, but my auger wss brilliantly quick, except when it caught on the main electric cable for the house, which had disguised itself as a root.
i could have used that spade for digging out the loose soil, but i used my hands instead.
I need to replace a couple of broken fence posts. The auger is fine in new installations but I've got to break up the concrete supports first.
Old 01-02-16, 07:25 AM   #663
Yes, I had that job to do first before using the auger. I have got one of those combi drill/breakers from screwfix which has been invaluable on so many jobs. Just big and powerful enough to break up the concrete.
Old 01-02-16, 05:36 PM   #664
Sir Trev
Sir Trev's Avatar
I may just have the same one. SDS jobbie that has just enough weight to get through Postcrete. Very, very useful as the chap we bought the house from was not very good at digging neat post holes and I often have lots to break up when replacing things.
Old 01-02-16, 05:49 PM   #665
admin
John T
admin's Avatar
I might have to look into getting one of those. It might be cheaper than hiring one.
Old 01-02-16, 06:25 PM   #666
Yep, that's the jobbie. I've given it loads of abuse, the only thing I've broken is some of the SDS chisels, because they've got stuck and I've used the drill to lever the bit & its snapped at the shank by the chuck, as its got no strength at that point.
I've had mine for at least 14 years, this is as close as I could find in the current catalogue. I noticed there others just above it in price that have higher rated motors, so they might be better?
http://www.screwfix.com/p/energer-en...230-240v/63303
Old 01-02-16, 06:30 PM   #667
admin
John T
admin's Avatar
Thanks. I'm tempted.
Old 01-02-16, 07:22 PM   #668
littleoldman2
littleoldman2's Avatar
Went to the lock up to move the SV (I do it regular to save the tyres). Whilst there fitted the fairing lowers and bought the battery home for charging. Decided to get the old girl MOTed this year so booked in for Saturday.
Old 01-02-16, 08:54 PM   #669
ophic
ophic's Avatar
You can get post repair anchors. You just bash them in between the old post remains and the concrete, then attach the new post to the top like any other anchor. Might save some effort.
Silver SV650SK3, Fuel exhaust
Old 01-02-16, 08:59 PM   #670
admin
John T
admin's Avatar
Yep. I've tried them in the past. I found they always go in wonky or they don't hold the post tight enough. Thanks for the thought though.
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
