06-04-14, 05:25 PM | #1 |
Pull clutch to start engine?
Having to pull the clutch in to start the bike?
06-04-14, 05:29 PM | #2 |
Re: Is this normal?
Yep. There is a safety switch by the lever. It's meant to stop you disappearing up the road starting it in gear.
Was: Red curvy S: crash bungs, double bubble screen, fenda extenda, HEL front lines, OEM belly pan Now: Blue FZ6 Fazer |
06-04-14, 05:39 PM | #3 |
Re: Is this normal?
06-04-14, 05:47 PM | #4 |
Re: Is this normal?
Yep, quite normal. You can bypass the switch, but on k3+ bikes this changes the fuel injection map so isn't ideal.
Jambo Sent without a real keyboard
Modern motorcycles are bloody brilliant, enjoy it while we can |
06-04-14, 05:47 PM | #5 |
Re: Is this normal?
Yep, always have to hold clutch in to start. Whether in gear or not.
And the bike cuts out if you engage 1st while the side stand is down too. Just good safety features |
06-04-14, 05:58 PM | #6 |
Re: Is this normal?
OK cheers for that. Can't quite see the point of it doing it in neutral tho' maybe it's just a Suzuki thing? As long as that's normal all is well in my garage. I know on the big Kwaks you can bugger the engines up big style doing this on a regular basis.
06-04-14, 06:06 PM | #7 |
Re: Is this normal?
06-04-14, 06:24 PM | #8 | |
Re: Re: Is this normal?
If you have a curvy there is no such trickery. Jambo Sent without a real keyboard
06-04-14, 06:27 PM | #9 | |
Re: Is this normal?
06-04-14, 09:18 PM | #10 |
Ditto.
Will it effect idling at lights? Can someone post a photo of what it should look like at the clutch lever? Thanks in advance Sent from my C6603 using Tapatalk
BREAKING MY SV - CLICKY CLICKY You laugh at me because i am different.. ....................................I laugh harder because you are all the same. |
Is it normal? | Dicky Ticker | Idle Banter | 5 | 20-01-11 11:10 PM |
Is the .org normal? | captainsmelly | Idle Banter | 58 | 21-07-09 12:26 PM |
Back to normal again. | rictus01 | Bikes - Talk & Issues | 0 | 29-01-09 08:20 PM |
is this normal | spakmitten | SV Talk, Tuning & Tweaking | 2 | 27-07-05 05:28 PM |
is this normal ? | mark | SV Talk, Tuning & Tweaking | 6 | 08-02-05 02:11 AM |
