Old 14-09-09, 01:27 PM   #1
SUPERSTARDJ01
Default Brakes pulling
Hi,
This morning I pulled the front brake on my curvey and it pulled to the right, now I don't mean the bike turnrd right like in a car it leaned right as though someone had pulled me.
Ideas?
Brake pads have around 1100 miles on them and I'm not a heavy braker.
Old 14-09-09, 01:30 PM   #2
husky03
husky03's Avatar
Default Re: Brakes pulling
get the calipers off and give them a service-no point in not doing it if you've had a braking issue
husky03 is offline   Reply With Quote
Old 14-09-09, 01:30 PM   #3
Alpinestarhero
Could be bad road surface (ruts left by excessive traffic, overlapping patches of tarmac). Did it keep happening?
Old 14-09-09, 01:31 PM   #4
fastdruid
fastdruid's Avatar
Unlike a car a braking discrepancy between calipers will *not* cause a bike to pull to one side.
I'd check everything was tight and couldn't move first.
Druid
Old 14-09-09, 01:35 PM   #5
SUPERSTARDJ01
It's happened twice on different parts of road, someone had suggested it could be some grit have got in the calipers not sure if that's true or not.
Old 14-09-09, 01:40 PM   #6
sinbad
You need to go out and try to make it happen again. (Carefully). Like Fastdruid says brakes can't "pull" to one side on a bike like they can on a car.
If braking actually has caused you too effectively countersteer to the left and as a result lean to the right and it was not a result of a dodgy bit of road like ASH suggests, then it's because the force involved caused something that could be loose to go out of allignment.
Either that or you braced yourself on the right hand side bar more than the left as you braked
Old 14-09-09, 01:41 PM   #7
husky03
husky03's Avatar
i'd still be taking them off and servicing them no matter what
Old 14-09-09, 02:14 PM   #8
sinbad
It never hurts, but it won't fix this problem (should a problem exist).
Old 14-09-09, 02:51 PM   #9
husky03
husky03's Avatar
for peace of mind (imoa)
Old 14-09-09, 02:54 PM   #10
Ceri JC
+1. Most small capacity bikes only have a disc on one side at the front (and think of your rear brake)! I would take it for a test ride and see if it happens again as it's possible that it was just chance that there was a groove/lump in the road surface pushing you to the side. Particularly common on the inside lane in motorways where lorries wear grooves in the road.
Pulling Off Quickly TheStudent Bikes - Talk & Issues 7 04-09-07 11:46 AM
Pulling wheelies to impress birds. Anonymous Idle Banter 77 23-02-06 12:28 PM
is my sv pulling how it shud? how quick is yours? kwak zzr SV Talk, Tuning & Tweaking 9 24-03-05 09:35 PM
it's worth pulling it off sometime... Shooter SV Talk, Tuning & Tweaking 0 01-01-05 08:24 PM
SV smashed by car pulling out SV Stu SV Talk, Tuning & Tweaking 28 31-12-04 05:04 PM
