Old 15-12-14, 07:08 PM   #1
DomP
Default SV maintenance costs?
I'm planning on getting an SV at some point when I've done my das. What sort of regular maintenance do they require over and above oil, filters, coolant etc. Are there any horrendously expensive major services.? Dom
DomP is offline   Reply With Quote
Old 15-12-14, 08:15 PM   #2
suzukigt380paul
Default Re: Maintenance costs sv
servicing is pretty much the same as the other big 3 japenese brands,except suzuki service intervals are shorter,by about 3 to 1(3 times more often that is)
Old 15-12-14, 09:56 PM   #3
DomP
Sorry I'm not well versed in motorbike service intervals, unless I'm putting lots of miles annually on it what would be the intervals?
Old 15-12-14, 10:33 PM   #4
Nutsinatin
Nutsinatin's Avatar
3500-4000 oil and filter (do yourself for £20), 7500 oil filter and spark plugs (do yourself for £27 - £34 depending on how many plugs your bike has), 11000-11500 oil and filter (do yourself for £20), 15000 oil filter possible air filter and valve clearances, costs £300-£400 at a dealer or garage although you can do it yourself if you feel up to it.
Buy a Haynes Manual, these are listed in it as well as how to do it.
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
Old 15-12-14, 10:36 PM   #5
Red ones
Red ones's Avatar
Default Maintenance costs sv
That's not quite right.
Compared with say a Fazer 8, the Yamaha has a service interval of 10,000km and the SV 6,000km. (6,000 miles and about 3,750)
But don't get me started. Why do NGK spark plugs last longer in a Honda or Yamaha block than they do in a Suzuki? Why do nuts and bolts need more checking on some makes than others? Why would an air filter block more readily?
Old 15-12-14, 11:18 PM   #6
DomP
Ah not too bad then.
Old 16-12-14, 12:23 PM   #7
SV650Racer
Plugs dont last any different between models. TBH the simple process of removing and inspecting the plug is just as important as changing it. Ive seen bikes come in for servicing that have never had the plug removed to be inspected and its rusted heavily making removal more difficult.
Air filters will get dirty quicker if your riding alot in town where the air is much more dirty and when riding in poor weather.
Old 16-12-14, 01:13 PM   #8
DomP
How are the valves timed then?
Old 16-12-14, 01:34 PM   #9
Foot
Either way, it's a pretty inexpensive for quite a lot of bike imo
Old 16-12-14, 04:14 PM   #10
Dipper
Dipper's Avatar
Valve timing is fixed as such and not a service procedure, valve clearances are.
Dipper is offline   Reply With Quote
SV costs? adam SV Talk, Tuning & Tweaking 1 11-06-12 07:04 AM
WTF PO costs Bibio Idle Banter 12 15-05-12 08:24 PM
Practice day costs? Sy-superfly Mini-Twins 12 10-01-12 09:45 PM
Bodywork costs. nikon70 SV Talk, Tuning & Tweaking 5 30-10-11 09:01 PM
Costs - The big one...... Jelster EuroTour 14 05-01-04 06:14 PM
