28-10-16, 11:27 PM | #21 |
Re: Swing Arm
29-10-16, 04:44 PM | #22 | |
Re: Swing Arm
True... It's worth it though. cool avatar man Last edited by Jacobus; 02-11-16 at 09:54 PM. |
02-11-16, 09:40 PM | #23 |
Re: Building From the Ground Up
03 GSXR 1000 Forks came in today. I think they are gorgeous. Also Got the swing arm painted
Next on the list is Cerakote the rims. Frame by Jacob Martin, on Flickr Last edited by Jacobus; 23-09-17 at 04:38 PM. |
02-11-16, 09:46 PM | #24 |
Hmmmm... Pretty.
Keep those updates coming. |
02-11-16, 10:29 PM | #25 |
We having a build off?
Sent from my SM-G935F using Tapatalk |
03-11-16, 09:47 AM | #26 |
It must be tempting to Cerakote the engine...
03-11-16, 02:31 PM | #27 | |
I'm going to loose, because I'm being motivated by my opponent's build thread, located HERE. Yea more than likely I'm going to attempt it... I hate prep work around sensitive parts though, like bearings, gaskets, etc. So that will be a lot of work. Aluminum Oxide will get everywhere and stick to everything. It doesn't matter how well you tape it off. Or I may just let it bump, depending on how it looks when I get it. I like the looks of all SV motors, black, steel, or mix, I like them.. If it was air cooled, then I'd cerakote it without question. I like the looks of the heat sinks one color and the fins another, I think that looks kinda snazzy. Last edited by Jacobus; 03-11-16 at 10:45 PM. |
03-11-16, 11:11 PM | #28 |
I took a socket an grinded the slots for the steering stem nut... Well it ain't pretty, but it was only 4 dollars, and I'm able to torque my steering stem to specs. The cheapest one I could find on eBay was 30. Make sure you get a deep or you'll be making two like I did.
04-11-16, 10:17 PM | #29 |
looks like all my photos have disappeared, any one else notice that. im able to see other photos in different posts. also looks like the link to the photos has been deleted from my text. wanted to check before I started repasting photos. I also opened a support thread. Yay Photobucket
04-11-16, 10:45 PM | #30 |
You're right, all your pictures have vanished.
Thread Tools | |
Building a rockery.. | tactcom7 | Idle Banter | 22 | 18-07-12 03:07 PM |
Building a dog pen/run | hongman | Idle Banter | 12 | 04-04-12 07:12 AM |
building a pc | aarond | Idle Banter | 14 | 13-11-09 08:53 PM |
What ever happened to ‘building up’? | Blue_SV650S | Bikes - Talk & Issues | 97 | 01-06-07 07:47 PM |
Any Engineers In The Building? | Jp | Idle Banter | 11 | 21-10-06 12:39 PM |
