Old 19-09-17, 02:04 PM   #1
Strangwooduk
Strangwooduk's Avatar
Question Fork Swap - GSXR - advise please
So folks another swap thred
i have GSXR 54mm forks
TL1000 wheel
Tokico 6 pot calipers
GSXR 55mm bottom yoke with bandit stem pressed in
Tl1000 top yoke
so for a start had to make a skim for the bottom yoke what a ball ache
done that and its happy
had a bandit stem pressed in to the bottom yoke (because they were going on my bandit)
so got a few queries
1 - Speedo drive - what the hell am i gonna do about this, the post to show what to do is no longer available
2 - bottom yoke - i still have the original gsxr stem, do i press that back in or what ?
3 - should i just get some different yokes to support what im trying to do ?
any help is massively appreciated
Strangwooduk is offline   Reply With Quote
Old 19-09-17, 06:08 PM   #2
Default Re: Fork Swap - GSXR - advise please
Using a K4 front end on my Sv, it's got GSXR top and bottom yokes, with standard stem.
Bottom bearing is same as Sv, top one you need to use the special sized top bearing. Can't remember the size off hand.
Speedo you need a Hall effect sensor and magnets glued into the disc rotor bobbins. Or run one off the back wheel.
Not sure if your front wheel is compatible with your front end?
Think Bibio says it should be a diamond spoke version.
Mines got the GSXR one.
SvRider forum has a lot of helpful advice
Old 20-09-17, 08:09 AM   #3
Strangwooduk
thats fine using a hall effect sensor but how many magnets
what spacing for the magnets ?
the whole front end fits together i was just concerned about what stem to use
so should i repress in the GSXR SRAD one ?
First time on V-Twin - Never looked back
Gen 1 Curvy 1999
Old 20-09-17, 07:26 PM   #4
Info is in Darren's thread here, 4 magnets
http://forums.sv650.org/showthread.php?t=204773
Old 20-09-17, 09:54 PM   #5
Strangwooduk
You my good sir are brilliant !! That helps loads !!
Might just try and buy a new set of triples to have no faffing around
Sent from my ONEPLUS A3003 using Tapatalk
Gen 1 Curvy 1999
Old 20-09-17, 10:02 PM   #6
Strangwooduk
Can anyone point me in the direction of some 50mm top and 54mm bottom yokes that I can put straight into the curvy Sv
Thank yalllll[IMG=300x700]http://uploads.tapatalk-cdn.com/20170920/bafd1a300c74978ee61e9d2389129b96.jpg[/IMG]
Gen 1 Curvy 1999
Old 22-09-17, 01:44 PM   #7
650
650's Avatar
check all balls conversion chart, I've no doubt whatsoever that the bandit stem will fit the SV with the correct bearings.
TL wheel should also be fine, this thread is the oracle of info tbh: http://www.svrider.com/forum/showthread.php?t=135430
93 VFR750 - WAY too many mods to list. Crashed
04 SV1000 - Bar end mirrors. Belly pan. Seat cowl. K4 GSXR600 K6 front end and custom top yoke. R6 Brembo MC
650 is offline   Reply With Quote
Old 22-09-17, 01:50 PM   #8
650
650's Avatar
compare stem length to that of the SV, by the way. You wanna make sure it petrudes enough to clamp down and isn't too long at the same time!
Old 22-09-17, 04:01 PM   #9
Mines using K4 GSXR 750 top and bottom yokes. Needs the odd size top bearing for it to work on a curvy
Available via Allballs
Read this thread
https://forums.sv650.org/showthread.php?t=225875
Old 22-09-17, 04:04 PM   #10
Strangwooduk
Read this thread
What size are the yokes for the forks ??
Gen 1 Curvy 1999
GSXR fork swap Mykey.M Bikes - Talk & Issues 3 05-01-12 01:26 PM
Lower Fairing Catching After GSXR Fork Swap Steve_God SV Talk, Tuning & Tweaking 3 20-06-10 09:01 PM
GSXR 600 K2 front fork swap? Neilvx SV Talk, Tuning & Tweaking 33 10-05-09 11:11 PM
SV GSXR Fork Swap - Keep Stock GSXR Damper? Mesomorphman SV Talk, Tuning & Tweaking 5 08-09-06 07:40 PM
GSXR Fork Swap svindaup SV Talk, Tuning & Tweaking 0 15-10-04 11:01 PM
