Old 31-05-19, 12:25 PM   #11
Adam Ef
Adam Ef's Avatar
Default Re: 2005 oil loss with slight scratchy noise rear cyl.
Originally Posted by mikerj View Post
It may have pushed a load of oil out through the engine breather when you had your accident. Might be worth checking inside the air box for excess oil.
+1
Worth checking anyway as it finds it way up there in small amounts over time and worth the occaisional clean out.
Past:
Old 31-05-19, 12:52 PM   #12
Lollie
Junior Member
Thanks folks,
I will be sure to check it out.
Lollie is offline   Reply With Quote
Old 01-06-19, 11:02 AM   #13
SV650rules
I can remember an old thread on here where an owner had his bike deliberately knocked over by scumb4gs and lay on its side for a while ( overnight ? ) got so much oil in one of the cylinders the bike suffered hydraulic lock. That oil may have gone through breather into air box and through open inlet valve ( or maybe oozed past the piston rings ).
2016 SV650 AL7
Old 02-06-19, 01:04 AM   #14
Lollie
Junior Member
Perhaps, although the bike was only on it's side for say a minute or so. All the riding around for the next few days seemed normal I think until I arrived home again after the long haul back. Thanks everyone for your input. I will explore all the suggested possibilities. Need to go and lube and tighten the chain now. Much obliged to you all.
Old 02-06-19, 08:16 AM   #15
Adam Ef
Adam Ef's Avatar
Have you changed the oil and filter since? That's probably the first thing I'd do, especially if it's anywhere near the mileage that would need it anyway.
Past:
Old 03-06-19, 05:54 AM   #16
Lollie
Junior Member
Yes, an oil change is due now anyway - 5000 Ks since last one. Was on my "to do" list. Thanks.
Scratchy/notchy gearshifts proze SV Talk, Tuning & Tweaking 5 30-04-19 09:24 AM
slight ticking noise Trickster2445 Bikes - Talk & Issues 15 24-04-13 05:38 PM
15,000 miles and slight humming/clicking noise ian505050 Bikes - Talk & Issues 3 23-08-11 01:40 PM
Loss of Power and Knocking Noise Gabriel2k SV Talk, Tuning & Tweaking 10 09-08-11 08:54 AM
Slight rear brake issue, back to triumph tomorrow Specialone Bikes - Talk & Issues 29 10-10-10 05:33 PM
