Old 01-11-15, 06:32 PM   #561
Nutsinatin
Nutsinatin's Avatar
Default Re: What have you tinkered with today?
Modified one of Bibio's gizmos to fit a 2002 Bandit and fitted a pair of heated grips to friends Bandit.
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
Old 01-11-15, 08:25 PM   #562
pookie
pookie's Avatar
@ntecuk
one you might have come across .. megane
Old 02-11-15, 10:31 AM   #563
Trev B
Trev B's Avatar
After putting bars on the pointy last summerI bought some mirror extender blocks and at £25 a pair(a tad expensive) they only improved the view of my elbows a bit,so purchased a pack of 4 rubber door stops from the £ shop and 2x70mm Allen studs and added them as well,they now eliminate the elbows and don't look bad either!!!sorry for some reason I can't upload pics at the moment
Somewhere up north,Never regret something that once made you smile!!!
Trev B is offline   Reply With Quote
Old 04-11-15, 03:26 PM   #564
admin
John T
admin's Avatar
New tyre today. Now have PR4's front and rear.
Old 04-11-15, 08:50 PM   #565
DomP
Adjusted the valve clearances on my Yzf r125, hopefully good for another 5k. What a pokey fiddly job.
DomP is offline   Reply With Quote
Old 05-11-15, 08:24 AM   #566
Swin
Swin's Avatar
Tinkered, or more accurately swore and raged at my SV, which started first thing, but then refused to start again after I'd filled up with fuel.
I suspect my starter motor is on its way out, so more tinkering in the very near future!
Riding a V-strom, well it has an Sv engine, don't it
Swin is offline   Reply With Quote
Old 05-11-15, 09:00 AM   #567
SIII
SIII's Avatar
Fitted my Stebel Nautilus Airhorn to my Triumph America. I had it on the SV, but couldn't find any space on the gixxer to fit, even splitting the compressor and horn, nowt much room under a gixxer fairing!
Used the loom I made up for the SV and just extended the leads to the Stebel. I took the feed for the relay from the original horn (did the same on the SV) and ran this to the relay and then the output to the Stebel. Means the original horn sounds a fraction of a second before the airhorn pumps out it's racket.
For such a big bike, no space under the seat for relays or bib's gizmo !!!
"You know, Scotland has its own martial arts. Yeah, it's called Fuk-U. It's mostly just head butting and then kicking people when they're on the ground"
The Stoppy King
SIII is offline   Reply With Quote
Old 07-11-15, 10:38 PM   #568
Mickle
Mickle's Avatar
Had a new front tyre fitted, the speed sensor drive came out in bits, which would explain the occasionally erratic speedo, so have ordered a new one,
Also made a pair of mirror extenders ( similar to what can be found on flea bay ) which seem to do the trick
Mickle is offline   Reply With Quote
Old 08-11-15, 05:02 PM   #569
N1xxl
Removed speedo drive and fitted captive spacer, removed coolant tank, removed fan, removed undertray and all electrics waiting for race subframe.
Old 08-11-15, 10:46 PM   #570
Jamesreabrookes
Spent the day de spider webbing a sv650s I bought as a project and cursing my brake bleeding problems
Next weekend probably going to be cursing electrics as can't get headlights to work either
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
