Old 22-02-19, 03:55 PM   #1
Craig380
Default K7 onwards versus K3 to K6?
I'm starting to look around for a replacement SV to replace my K6S. There seems to be quite a few of the K7-onward twin-spark bikes around.
Are they much more complicated to maintain compared to the K6?
In nearly 4 years and 22,000 miles on the K6 I never needed to touch the TPS or carb sync, as I never had a problem with lumpy running at low rpm or low-speed jerkiness. Are the twin-spark bikes just as easy to look after?
(To the curvy crew: sorry, I prefer pointies )
Old 22-02-19, 04:41 PM   #2
Default Re: K7 onwards versus K3 to K6?
when it comes to servicing then its 4 plugs instead of two. you can DIY sync the TB's as you need the "special" tool or get your dealer to do it, top tip if you get your dealer to do it is fit vacuum extensions before you take it in.
i've done many TPS adjustments on peoples bikes and its well worth doing.
oohhh and the twin sparks get better MPG then the single sparks.
Old 22-02-19, 05:05 PM   #3
Craig380
Thanks Bibs - plugs I can manage, and if I remember right the TPS adjustment method is almost the same on the K7 onward, isn't it?
So it's just the TB sync that needs the special tool to manage the idle control or whatever?
Old 22-02-19, 06:01 PM   #4
yup that should have read cant DIY.. my bloody dysl.... strikes again.
yup just the TB sync that needs the tool. it needs done every 20k or so as they do go out of sync.
good news is that you never have to play with a tick over screw
Old 22-02-19, 06:58 PM   #5
glang
you should be able to ABS as well shouldnt you?
Old 22-02-19, 09:31 PM   #6
Craig380
Don't judge me, but there's a very clean-looking 11-plate 650 Strom with ABS in a local dealers, accessories like heated grips, hard panniers etc, I'm quite drawn to it. Cheaper than an equivalent SV too ...
Perhaps I got an undiagnosed concussion during the crash
Old 22-02-19, 09:48 PM   #7
glang
hey nothing wrong with wanting ABS and as for a Strom well I suppose its almost as good as an SV.....
Old 25-02-19, 07:16 PM   #8
SV650rules
https://www.v-strom.co.uk/smf/index....79c&board=58.0
Welcome to UK wee-strom forum..
V-stroms always seem to get good writeups in road tests..
2016 SV650 AL7
Old 25-02-19, 07:53 PM   #9
Craig380
I've been looking at the 2012 - 16 models (without the 'beak', and with the Gladius-derived engine), and I do quite fancy one ...
Own a Kawasaki ER6 or Versus? NewsBot News 0 06-03-14 05:30 PM
Own a Kawasaki ER6 or Versus? NewsBot News 0 06-03-14 03:10 PM
A to B - Car versus Bike Amanda Idle Banter 12 22-07-10 11:15 AM
Remus versus Akrapovic curium Bikes - Talk & Issues 10 08-06-06 07:18 PM
K5 Versus K6 richieazer SV Talk, Tuning & Tweaking 6 05-06-06 02:36 PM
