Old 16-02-05, 06:28 PM   #1
youdaman
Default Accessing spark plugs
I just got my g/f a 2000 SV650. I want to change the plugs, air filter, and oil before any real riding occurs. No manual came with the bike so we ordered a Suzuki service manual. How or what is the best way to access the spark plugs on this generation bike. I have a 2002 GSXR600 so I was hoping it's just as easy as my bike. Thanks for the advice.
Old 16-02-05, 06:42 PM   #2
Red ones
Red ones's Avatar
Get some spare knuckles! You'll need them when you get to the front plug (behind the horn after loosening the rad a bit)
The top plug is ok (under the tank and air box)
Old 16-02-05, 06:51 PM   #3
Scoobs
Vipers Pillion Bitch
Scoobs's Avatar
Undo the horn and let it dangle, loosen the rad and hinge it forward. Its a tight squeeze and awkward but pretty easy. Get a spark plug spanner with a rubber ring in it and use this to pull the plug out of the hole after you have unscrewed it. The top plug is easy when you have the tank up.
I look good, I mean really good! Hey everyone come and see how good I look!
Scoobs is offline   Reply With Quote
Old 16-02-05, 07:26 PM   #4
The most suitable plug spanner is the one that comes with the bike's toolkit, it's articulated so as to easily fit into the narrow gap between the rad and the cylinder head, it is also fitted with a plug-gripping rubber insert, making it easy to remove the loosened plug.
Old 16-02-05, 07:34 PM   #5
Yup, it's the only good tool in the toolkit really...
Old 16-02-05, 08:53 PM   #6
embee
embee's Avatar
...and while on the subject, if the bike hasn't already got one, fit a front fender extender asap.
it'll minimise the likelihood of the V-twin turning into a 325cc single when the road gets damp.
Oh, and check that the drain holes in the plug recesses are clear, the front one comes out on the right side of the cyl head. You'll very probably find the front plug has a rusty tide mark on it where the water has been sitting in the front plug bore.
Many people recommend some waterproof grease (I use vaseline) around the front plug cap where it seats on the cylinder head to prevent water getting in. Note the arrow marks on the caps to get the alignment correct.
Rate my spark plugs DarrenSV650S SV Talk, Tuning & Tweaking 23 11-11-08 07:58 PM
spark plugs daddy_sperm SV Talk, Tuning & Tweaking 12 01-03-06 06:12 AM
Spark Plugs fred_dillon SV Talk, Tuning & Tweaking 5 19-06-05 06:45 PM
Spark Plugs valleyboy SV Talk, Tuning & Tweaking 15 18-05-05 07:51 AM
spark plugs weegaz22 SV Talk, Tuning & Tweaking 4 04-08-03 05:04 PM
