Old 30-04-18, 07:09 PM   #1
Red ones
Red ones's Avatar
Default Clutch lifter replacement
I need to replace the clutch lifter thingy. The bit with little balls of cheese that wear out far too easily.
It's an SK8. Is it he same part number as all other models? I'm assuming it's a part they haven't changed ever.
Old 30-04-18, 08:52 PM   #2
SV650rules
Default Re: Clutch lifter replacement
The AL7 (2016 >) has a rack and pinion system.
2016 SV650 AL7
Old 01-05-18, 01:07 AM   #3
Talking Heads
Sounds like the desired part is roller bearing 22...?
The AL7 has a camshaft type clutch actuator same as the SFV.
https://www.bike-parts-suz.com/suzuk...2461021/M/8005
Talking Heads is offline   Reply With Quote
Old 04-05-18, 10:26 AM   #4
Red ones
Red ones's Avatar
Cheers all. Part ordered, delivered and fitted.
Now clutch lifter mechanism. garynortheast Bikes - Talk & Issues 3 14-10-14 05:13 PM
Lubricating clutch lifter? Pricey12 SV Talk, Tuning & Tweaking 5 11-07-14 04:30 PM
Clutch lifter assy. yorkie_chris Stuff Wanted 7 17-10-09 05:16 PM
clutch lifter assembly mjc Stuff Wanted 0 01-06-09 05:46 PM
Clutch lifter problem. swinging_simian SV Talk, Tuning & Tweaking 6 29-05-09 02:18 PM
