Old 30-04-17, 12:10 PM   #1
Bartonam88
Default Brakes still soft after rebuild
Hopefully someone can help my extremely frustrating situation.
I've been dealing with soft front brakes for months and tried everything to rectify the problem. Bled and bled them, tried removing calipers and bleeding them with the nipple at the highest point of the system. Still no luck..
Bought braided lines, new pads, new caliper seal kit, new pistons (as old seals had persished and pistons were pitted) and cleaned out all the salt and grime from the caliper.
Built the calipers back up, bled the lines and still the brakes are rubbish. I don't even have to apply much pressure to the lever and its touching the handlebar..
Is there anything else i can try without a caliper upgrade?
Thanks a lot
Old 30-04-17, 02:03 PM   #2
R1ffR4ff
R1ffR4ff's Avatar
Default Re: Brakes still soft after rebuild
Have you tried a new Master Cylinder or Master cylinder rebuild kit?
What year and model?
Old 30-04-17, 05:35 PM   #3
glang
And how did this come about? Did the lever slowly get softer, was it overnight, after you'd done some work on the system?
Old 30-04-17, 05:45 PM   #4
Bartonam88
The bike is an sv650s k7. Haven't touched the master cylinder yet but i don't want to keep pumping money into it and get nowhere, are there any common problems that occur with the master cylinders?
The brakes have always been quite soft, they stop the bike but i did a track day a few weeks back and under hard braking the lever was all the way back to the handlebars.. Which wasn't ideal.
Cheers for the replies guys
Old 01-05-17, 01:44 PM   #5
NTECUK
NTECUK's Avatar
Clapping the lever back over night might be a help.
Bunggie or something ekestical
Old 01-05-17, 03:34 PM   #6
aesmith
Something wrong with the master cylinder would be my guess. The SV brakes are quite straightforward to bleed with no special tricks needed, so if you've had a couple of goes then it's unlikely that you haven't got that part sorted.
New pads can give increased travel when they bed in, but not that much. When I've changed the pads I've just set the lever further out, and it sorts itself out after a couple of hundred miles.
Old 01-05-17, 04:40 PM   #7
No point going for a calliper upgrade, even if it was easy or straight forward, as there are no straight swaps without a new calliper bracket.
Sv brakes are perfectly good enough for SV racers when in good order.
As you said, yours have always been soft, so that's maybe a clue, even after changing most of the major parts.
Agree with the others, master cylinder seal would be the likely culprit, and cheaper to replace than the callipers. Service kits are available, although the circlip is a pig to remove.
Old 01-05-17, 09:10 PM   #8
Bartonam88
Ok brilliant, cheers for all the info!
Will post back if i get anywhere with them
Old 02-05-17, 12:12 PM   #9
check you have the brake pad rattle springs the right way round, the large leafs go to the piston.
if you over fill the blind holes for the sliding pins on the carrier/calliper it will cause suction which will also give spongy brakes.
what did you use to put the piston/seals back in with. RRG?
Old 03-05-17, 10:25 AM   #10
embee
embee's Avatar
Do you use a vac bleeder system? If not, get one.
Various makes available, I use a Mityvac which is good quality, I can't vouch for other makes. A mityvac is somewhere in the £30 bracket but will save you all this hassle, I changed the brake fluid on the ABS combined brakes on my NC Honda a few days ago, took around 20mins total. One go, done.
purely as examples
https://www.amazon.co.uk/Mityvac-MV8...ustomerReviews
https://www.amazon.co.uk/d/Car-Brake...DJ4K7MHKBWV2X6
Brakes not as sharp after rebuild Alexander94 SV Talk, Tuning & Tweaking 7 21-07-15 04:47 PM
My RGV 250 Rebuild danf1234 Photos 44 11-05-13 08:01 PM
Another rebuild hardhat_harry Photos 15 14-03-12 08:13 PM
Front brakes, strip + rebuild, replace or upgrade? 7755matt SV Talk, Tuning & Tweaking 6 20-12-09 08:22 AM
Rebuild. John 675 SV Talk, Tuning & Tweaking 15 26-08-08 06:22 PM
